Tip & How-To about Computers & Internet
Windows XP Tweaks
Services to turn off:
Alerter
Application Management
Automatic Updates
ClipBook
Distributed Link Tracking Client
Error Reporting Service
Fast User Switching Compatibility
Messenger
Portable Media Serial Number Service
Remote Registry
Routing and Remote Access
Task Scheduler
Telnet
TPC/IP NetBIOS Helper
Uninterruptible Power Supply
Change "Recycle Bin" size to 1%
Registry Hacks:
Auto Sort Start Menu
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\MenuOrder
Go to Edit/Permissions, click Advanced, clear the "Inherit From Parent" check box, click Copy from the dialog box, click OK and then clear the "Full Control" for your account and now Windows will autp sort the start menu, but you can still do it too
Disable User Tracking
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
Add or Edit DWORD = NoInstrumentation, Value = 1
Disables Windows user tracking; better performance, much better privacy
Cache Thumbnails
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
Add or Edit DWORD = DisableThumbnailCache, Value = 1
Disables thumbnails in Windows, saving hard drive space
Kill Chrashed Apps Quicker
HKEY_CURRENT_USER\Control Panel\Desktop
Add or Edit Sring = HungAppTimeout, Value = 1000-5000
Cuts time for Windows to recongize a crashed application and allow you to kill it; default is 5000(for 5 seconds)
Faster Start Menu
Add or Edit Sring = MenuShowDelay, Value = 0 - 400
Changes the delay that for Windows to show a menu in the start menu; value is in ms
Network Intelligently
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters
Add or Edit String = DisableTaskOffload, Value = 1
Frees processor from doing network-card work
Browse the Network Faster
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\RemoteComputer\NameSpace
Delete subkeys {2227A280-3AEA-1069-A2DE-08002B30309D} and {D6277990-4C6A-11CF-8D87-00AA0060F5BF}
Speeds up network browsing of old Windows machines on the LAN by ignoring their scheduled tasks and printers
Remove Compression Option In Disk Cleanup
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\VolumeCaches\Compress old files
Delete the Default Value Key and the next time you start Disk Cleanup, it will skip the compression analyisis
Computers & Internet Logo
my pc stoped after 30 min
Dual Channel supported up to 4GB DDR2 533/667 MHZ [XP will only see 3 GB x86 / 32bit]
Freezing is most likely caused by a faulty hard drive, or faulty RAM. I would test both for faults.
Jun 01, 2010 | Acer Aspire 5500 5570-2609 Laptop
too much memory consumption
Ok. First of all, what Windows version you have?
Second, to ease up your problems, let us start by cleaning up the system. Yes it is a new installation, but there are stuff that you can remove that won't harm your system and it will ease up the pressure.
This will be a long file, so hold your breath.
Firstly, assuming that you have administrator access, or your account is Computer Administrator, click start, click run and type 'services.msc'.
Now if you are opening this for the first time, i will look confusing. Simply look at the bottom of the window, you will see Extended and Standard. Choose Extended.
The following list is what you need to disable.
Simply right click on and click properties, and click the drop down box and click disable.
All of these services can be safely stopped with no adverse effects on your system, except for a faster boot up, and a better performance.
Alerter(Notifies selected users and computers of administrative alerts)
Application Layer Gateway Service(Internet Connection Sharing)
Automatic Updates(Unbelieveable.... Takes up lots of space and resources)
Backgroung Intelligent Transfer Service(Uses idle bandwidth to transfer data)
Clipbook(This is not needed)
Computer Browser(Used to view other computers on a network)
Distributed Transaction Coordinator(This is not needed)
DNS Client(Resolves and caches DNS)
Error Reporting Service(Sends reports to Microsoft)
Help and Support(Enables Help and Support Center - Should not be needed)
Human Interface Device Access(Enables generic input access to HID)
Indexing Service(ndexes contents and properties of files)
IMAPI CD-Burning COM Service(Used for burning CD's, i am sure you have Nero)
Internet Connection Firewall (ICF) / Internet Connection Sharing (ICS)
Messenger(Annoying popup messages once on internet)
Net Logon(Supports pass-through authentication of account logon events)
Netmeeting Remote Desktop Sharing(Enables an authorized user to access this computer remotely)
Remote Desktop Help Session Manager(Manages and controls Remote Assistance)
Remote Procedure Call (RPC) Locator(RPC name service database)
Remote Registry(Used to modify registry settings on this computer)
System Restore Service(Performs system restore functions)
TCP/IP NetBIOS Helper(This is Not Needed)
Telephony(Support for programs that control telephony devices and IP connections)
Telnet(Enables a remote user to log on to this computer)
Terminal Services(Multiple Users connected to PC)
Themes(Provides user experience theme management)
Uninteruptible Power Supply(Manages a UPS)
Upload Manager(Manages synchronous and asynchronous file transfers)
Wireless Zero Configuration(Provides automatic configuration for the 802.11 adapters)
Workstation(Creates and maintains client network connections to remote servers)
PLEASE COPY THIS LIST INTO NOTEPAD AND THEN WORK WITH IT. IT MAY BE CONFUSING.
Ok. When you are done, restart your pc.
When it has booted back up, go to my computer and right click on the hard drive you are using.... all of them... and click properties, then click 'Disk Cleanup'
Let the thing load and then tick all of the fields by clicking on them. Then click ok.
Let it run through. Do this on all hard drives.
Next, and hopefully what will cause a drastic change, your pagefile.
Right click on My Computer and click Properties, click on the Advanced tab and click on the first Settings button under Performance. A window will pop up and you will see Visual Effects. Click Adjust for best Performance, which is the 3rd Tab. Then, click apply. Let it do its thing, then click advanced and at the bottom, you will see Change. Click that.
If you have 2 drives on your computer, or 1 drive split in 2 or more, that will be great.
Simply choose the 2nd drive, once it is not the main one, and click custom size. Depending on the space empty on the drive, type 2000 in both boxes. Then click set. Then go to your main drive which should be "C:" and click No Paging File. Then click set.
Ok. Now, finally coming to easing up your hard drive space.
Go here and search for ATF Cleaner.
Download it, its free and when it is done, click Select All and then click Empty Selected. Let it do its thing and reboot your pc afterwards. See if you notice a change in the system performance.
Now this part is tricky. You need to go into your main drive, c: and click tools>folder options, click view and tick everything in there, except Hide protected operating system files (Recommended). Also, click Show hidden files.
Then, look for hidden folders with names like "17c362e648ec4aa3e30187024666a5c3" and so on. Delete them, then reboot...
That is the best that i can do for you now...
Hope you see some changes....
Oh...Do a defrag now and then...
Right click your drive, click properties and click tools
Then click Defrag....
Hope this works...my hands are tired now....Laters....
Jul 19, 2008 | Microsoft Windows Vista Ultimate Edition
217 people viewed this tip
David Payne
David Payne
