Tip & How-To about Computers & Internet
How to tweak your computer
Step 1
Back up important files. This includes impotant datas stored on your computer
Step 2
Update the firmware of your computers BIOS. Also update or patch your OS to the lates update and even your hardware devices must be updated as well.
Step 3
Also before proceeding ,remember to get a BENCHMARK test program that will help you see the changes and also monitor the temp. of your processor after overclocking
Make sure that your BIOS is also set to shutdown once illegal voltage or temp. will be detected
Step 4
Ensure that the CPU FAN is clean and is still calibrated to the right rpm
Step 5
Power on your unit ,hit the hotkey to access setup.On the BIOS go to ADV. CHIPSET option.Then look for"clocks, "frequency/voltage control" or "voltage options." This will look unique on each brand of computer.You can overclock by modifying "CPU bus frequency" or "CPU FSB frequency." Increase this value slightly. In some cases, you will be able to increase your "CPU multiplier" through the BIOS.If your BIOS has none of these options,your motherboard is not capable of overclocking the processor.
Step 6
You can also try overclocking your MEMORY AND VIDEO speed. Some motherboards have this options on the BIOS as well
Step 7
You can consult your motherboards manual to know the operating voltage of your cpu or type in the model of the board on yahoo or google.
Computers & Internet Logo
How do i update my Archos 504?
How to install firmware ..?(update)
Step 1. Download the firmware to your computer-->click HERE to download the update file When you download the update file, your browser may warn you that the file 'could be harmful'. This is normal because browsers are not familiar with files that have a .AOS extension and suspect that they could be malicious. These files are not harmful to your computer.
Step 2. Turn on your ARCHOS device and connect it to your computer with the USB cable
Step 3. On the ARCHOS, choose to connect and wait a few seconds for your device to be detected by the computer
Step 4. Copy and paste the downloaded firmware (.AOS file) to the ARCHOS device.
  • Case 1: logo_firm_hdd.jpg Your ARCHOS is detected by your computer as a Hard Drive (E: for example) in Windows® Explorer. Paste the update file directly onto the ARCHOS hard drive icon.
  • Case 2: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see just two folders Data and Media when you open it. Paste the update file into the folder called Data.
  • Case 3: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see Internal Hard Drive when you open it. Open this Internal Hard Drive icon and you will see the various ARCHOS folders inside (Video, Music, etc.). Paste the update file into this area but be careful not to paste it into any of the folders there.
Step 5. Disconnect the Device
Unplug the USB cable (for 'Mobile Device' connections) or use the "safe disconnect" green arrow icon (for Hard drive connection) in the system tray before unplugging the USB cable.
Step 6. On your ARCHOS device, click on "Update Firmware"
Click on the "tab" button to show the settings screen. Select the "System" icon and then click on the "Update Firmware" button. For the ARCHOS 104, 202, & 204, go to the settings and open the icon "System" where you can find the Update Firmware button.
Dec 31, 2010 | Archos 504 500870 Digital Media Player
FIRMWARE for Sanyo xacti vpc-hd2000!?
Updating Firmware on Xacti HD2000
This page explains how to download and install the firmware update for the VPC-HD2000.
  • This firmware is for the VPC-HD2000 only. Please do not install it on another model.
  • By installing this firmware Greek, Swedish and Finnish will be added as new menu languages. (Please notice that for this purpose the menu languages Traditional Chinese, Simple Chinese and Korean will be deleted!)
    It is not necessary to install this firmware update when there is already the possibility of choosing Greek, Swedish or Finnish as menu language! Please check this before continuing with the update.
  • Before updating the firmware, please read through the explanations on this page.
  • Make sure to update the firmware in the order shown below.
  • The camera might not boot up properly if its power is turned off during the firmware-updating procedure.
  • Please read the accompanying licensing agreement before downloading this firmware. Downloading the firmware automatically implies your acceptance of the licensing agreement.
Requirements:
  • SD memory card (henceforth referred to as "card") with capacity over 8 MB.
  • Fully charged lithium ion battery.
  • Additionally, you need one of the items listed below:
    (i) A SD memory card reader (henceforth referred to as "card reader")
    (ii) A dedicated USB interface cable (shipped with the camera).
CAUTION
Be sure not to take out the battery during the updating procedure (this lasts about 60 seconds).
Avoid operating the buttons on the camera or closing the monitor unit during the updating procedure.
I) Preparing to update (copying the firmware onto a card)
Step I.1: Format the card on your camera*
  • Turn the camera on and set the "REC/PLAY"-button to "PLAY"
  • Press the "MENU"-button.
  • Move joystick to the left and select "OPTION MENU 3".
  • Move joystick to the right and select "FORMAT". Press the "SET"-button.
  • Select "FORMAT". Press the "SET"-button.
  • Select "YES". Press the "SET"-button.
    *CAUTION
    If you format a card, all images and data stored on that card (whether protected or not) are deleted! Please be sure to move or copy important images and data to a PC or to another card!
Step I.2: Download the Firmware*
  • The firmware can be downloaded here.
    icon_dl1.gif Firmware Update XACTI HD2000
    s313n081.bin (7.5 MB)
    *CAUTION:
    Please be sure to download the file onto a hard drive and not onto a removable location such as a card reader.
    The firmware file should be saved in a location where you can easily find it again later (e.g. save it on desktop of your computer).
Step I.3: Copy the file "s313n081.bin" to the formatted card (from step I.1):
The method of operation differs depending on whether you use a card reader (i) or a dedicated USB cable (ii).
(i) When you copy the downloaded files with a card reader: (1) Put the formatted card from step I.1 in the card reader. (2) Copy the "s313n081.bin" file created on your hard disk in step I.2 to the root directory of the card.
(ii) When you copy the downloaded files with a dedicated USB cable: (1) Connect the camera to your PC with a USB cable and turn on the camera. When you connect to your PC, please make sure the camera's USB interface is set to "Card Reader". (Please refer to "Setting the Connection Mode" on pages 7 to 8 of the Instruction Manual in the Xacti Software CD 1.0) Please make sure the camera is recognized as a removable disc. (2) Put the formatted card (from step I.1) in the camera and then copy the "s313n081.bin"-file created on your hard disk (in step I.2) to the root directory of the card.
(3) Remove the camera from computer.
Please read "Dismounting the Camera" on pages 9 to 11 of the Instruction Manual in the Xacti Software CD 1.0 for a description of how to disconnect the camera.
II) Updating firmware on the camera itself
CAUTION>:
Do not turn off the power during the updating procedure (this lasts about 60 seconds)!
  • If the power is turned off during the updating procedure, the update may not be properly completed and the camera may not start up.
  • To prevent the battery from running out during the updating procedure, please use a fully charged Lithium ion battery.
  • Do not remove the battery during the updating procedure.
  • Do not operate the buttons on the camera or close the monitor during the updating procedure.
Step II.1: Insert the card with firmware-update file (from step I.1) into camera
Step II.2: Turn the camera on and set the main switch to "PLAY".
  • The playback screen will be displayed.
  • If the camera is in SIMPLE mode, switch it to NORMAL mode.
Step II.3: Press the "MENU"-button.
  • The menu screen will be displayed.
Step II.4: Choose "OPTION MENU 3"
Step II.5: Choose "FORMAT" from the Menu Screen, but do NOT go into "FORMAT"
Step II.6: Move joystick to the left for more than 2 seconds.
  • The update screen will be displayed.*
    *No Update Screen
    If the update screen is not displayed, it's possible that the update file was not copied onto the card. Please refer to "Preparing to Update" to copy the update file onto the card and follow the updating procedure once more.
    If the main switch is set to "REC", the update screen will not be displayed. Make sure the main switch is set to "PLAY".
Step II.7: Choose "YES" and press the "SET"- button.
  • Updating will start.
  • During the updating procedure, the screen will show the message, "LOADING. DO NOT POWER OFF", and the access light will flash.
    Please do NOT turn the power off during the updating procedure! (this takes about 60 seconds).
Step II. 8: When the updating procedure is completed, the camera will turn off automatically.
  • Please remember to format the memory card once more before using it again.
Oct 15, 2010 | Sanyo Xacti VPC-HD2000 High Definition...
my view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is there anyhting i can do to fix it?
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Got unlocked iphone, tried to restore factory settings now its stuck on bitten pineapple...any help plz just got this phone?
Here u can follow the steps
Step 1: Make sure you have downloaded the latest version of iTunes if you haven’t already. Download iTunes 8.2 from the link given below.
Step 2: Now connect your iPhone with your PC. You must connect it to a single usb port on the backside of your computer. Do not use any usb hub or the ports in the front as this could cause an error during update process.
Step 3: Start iTunes 8.2. Sync your iPhone with your PC so that iTunes backs-up all your important data including settings, apps, music, contacts and photos.
Step 4: You will now have to download a custom cooked firmware for your iPhone version (2G or 3G). I can’t post the download links for these files for the reasons you all know very well. Just Google “iPhone 2G Custom 3.0” (If you are using iPhone 2G) or “iPhone 3G Custom 3.0” (If you are using iPhone 3G) and use one of the torrent links to download the custom created .ipsw file.
Step 5: Once you have downloaded the required .ipsw file, Copy/Paste it into this location:
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows 7)
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows Vista)
“C:\Documents and Settings\[username]\Application Data\Apple Computer\iTunes\iPhone Software Update\” (Windows XP)
Step 6: Restart iTunes. You will now be prompted to install this firmware you just download. Just close this prompt dialog by clicking on “x” from the top right-most corner of the window.
Step 7: Now you will have to restore your iPhone to this custom firmware 3.0 that you just downloaded. Click on your phone from the sidebar in iTunes to get to this screen as shown in the screenshot below:
Now press and hold left “Shift” button on the keyboard and then click on “Restore” (Not “Update) button in the iTunes and then release the “Shift” button.
This will make iTunes prompt you to select the location for your downloaded custom firmware 3.0. Select the downloaded .ipsw file and click on “Open”.
Step 8: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps some of which are highlighted below:
Don’t do anything silly at this point. Just wait while iTunes installs the new firmware 3.0 on your iPhone. Your iPhone screen at this point will be showing a progress bar indicating installation progress. After the installation is done, iPhone will restart automatically and you should now have a fully unlocked and jailbroken iPhone 2G. iPhone 3G on the hand will only be jailbroken, not unlocked. iPhone 3G users will have to wait for Dev-Team to release ultrasn0w on Cydia in order to unlock their phones.
Step 9: Once you are done with the unlocking and jailbreak process. You can now restore all your settings, apps, music, contacts and photos to the newly installed firmware version 3.0 by restoring the backup that you made in Step 3 from iTunes.
Feel free to ask me any question here should you run into any problem during the update process.
Disclaimer: This guide is for testing & educational purposes only. I’m not responsible for any loss of important data or malfunctioning of your iPhone.
Download Links:
Download iTunes 8.2
Download iPhone OS 3.0 Custom Firmware (iPhone 2G) [Screenshot]
Download iPhone OS 3.0 Custom Firmware (iPhone 3G) [Screenshot]
/**/ Thanks
Thiru
Jun 20, 2009 | Apple iPhone Smartphone
certain songs on my Sansa m240, will not play
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade
2. Click OK to continue the firmware update.
3. Click OK to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
1. If it's not installed yet, download and install the Sansa Firmware Updater
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the following message will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
184 people viewed this tip
David Payne
David Payne
