Tip & How-To about Office Equipment & Supplies
How to remove the printhead of a kodak all in one printer
Open the top access door of the printer, once you see the printhead dock to the center place your index finger on the "bullseye" sticker on the printhead , then move your index finger going to the top left, try pushing the notch above to eject the printhead.
You can use this procedure if you will get a blank sheet print out after a paperjam.
change print head on kodak 5300 printer
Are your asking how to replace the printhead?
First you need to turn On the printer and open the printer access door where you can see the Ink. Now wait for the Printhead to stop into the middle then remove the ink cartridges both ink and black., Now to rmove the Old printhead you need to press a Tab which is hidden on the printhead., heres the step to remove the printhead which for me the hardest part
-Point your index finger on the white sticker that attached on the printhead or the bullseye sticker(If theres no white sticker on the print head just put your index finger on the middle of the printhead)
-Now your index finger is on the middle of the white sticker right? Move your index finger upward unti you feel a latch that you can press., Just press and full then your printhead wil be removed
-Now Your ready to insert your new printhead
-To insert new printhead just put the printhead on the carriage of the printer and gently press the white sticker of your new printhead make sure that you will hear a clicking sounds then put your cartridges back
-Theres some instances that the printhead will not stay on the middle., it keeps on staying on the right or on the leftside for you to solve that heres the step
-Turn on the printer open printer access door and wait for the printhead move into the center and if the printhead its on the center immediately unplug the power cable so the printhead will not move.
GudlucK
Nov 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
how to install a new printhead in 5500
GudlucK
Nov 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
How do I remove a Kodak 5300 All-in-one printer heade?
there are 2 release tab located on the gap between the printhead wall and the carriage, one is located on the upper left hand corner of the printhead wall and the other one is located right at the top center of the printhead wall. All you have to do is to press any of these tabs to unlock the printhead and to release the printhead from the carriage.
Mar 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
installing new printhead
Make sure the printer is turned on.
Nov 19, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
343 people viewed this tip
k24674
