Tip & How-To about Computers & Internet
System performanace improvement
The following steps will help to improve your system performance:
1. Don’t download any unknown software/application from the internet which will cause virus infection and slow down your system performance.
2. Always update the latest Virus definition, whenever released from Antivirus product vendor.
3. Delete the temp and temporary internet files from your profile once in a week.
4. Check and set the paging file size 1.5 to 2 times of your physical RAM.
5. Scan full system disk for virus atleast once in a week.
6. Check and scan the HDD for any errors using following steps:
Go to c: drive properties>tools>error-checking and select check now.
In command window, Type chkdsk /f x where x is your drive letter of the HDD.
7. Check free space for System drive, it should be more than the paging sige configured.
Computers & Internet Logo
bb 9550 getting 365 error what can i do to fix it?
App Error 365 is a software error, most often related a theme or third party application you've installed.
Follow these directions:
1) Make sure you have Blackberry Desktop Manager installed.
http://us.blackberry.com/apps-software/desktop/
2) On your PC, go to Start > Run and copy and paste the following line exactly (meaning with the quotation marks):
"c:\program files\common files\research in motion\apploader\loader.exe" /nojvm
3) The Application Loader Wizard will appear -- click "Next."
4) In the "Connection:" drop-down menu, you should see "USB-PIN: UNKNOWN". Click the "Next" button.
5) You should then see a list of applications ready to be installed for your Blackberry. Hit Next and Finish and you are well on your way to getting your Blackberry back to life.
Just don't disconnect anything and let the lengthy process finish completely.
NOTE: If you do not see a list of applications mentioned in step 5 and instead see the message "The Blackberry Desktop Software does not have Blackberry Device Software for the device that you have connected to the computer. Contact your wireless service provider or system administrator," then you must download Blackberry's Operating System for your carrier and device.
http://www.blackberryfaq.com/index.php/BlackBerry_Operating_System_Downloads
Just select the appropriate carrier and network type, select your Blackberry model from the list and download the latest version. Install this download and follow the above steps again and you should be on the right path.
I hope this helps.....
Good luck
Apr 30, 2011 | RIM BlackBerry Bold 9700 Smartphone
mi bb 9700 mostro error 523 y no lo puedo utilizar necesito ayuda gracias
App Error 523 is a software error, most often related a theme or third party application you've installed.
Good luck
Apr 29, 2011 | RIM BlackBerry Bold 9700 Smartphone
Quickbooks accounting software fatal error
QuickBooks Customer Service Helpline Number +1-800-477-8031 for instant services and fixing software errors.
Click at given link for more details:-
https://www.qbsupportnumber.com/
Mar 15, 2010 | Intuit QuickBooks Simple Start Edition...
Youtube Buffering is so slow
There could be a wide variety of reasons for slow buffering times.
1) Your area could have alot of people on youtube at the same time, causing the local servers to be overloaded.
2) You could have slow internet capabilities with your current internet service provider.
3) You may be using an out-dated web browser, or have too many plug-ins installed.
4) You may not have sufficient ram on your computer.
I would recommend using a browser such as the latest version of google chrome for fast speeds watching flash, and you could try certain software to speed up your video watching speeds, such as http://www.videoaccelerator.com/. And you may want to check out that your internet service provider is giving you good download speeds.
I hope that helps!
Mar 11, 2010 | YouTube Computers & Internet
263 people viewed this tip
David Payne
David Payne
