Tip & How-To about Office Equipment & Supplies
Error code CANON iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E000
0000
The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000
The main thermistor detects 250°C or higher.
0001
The main thermistor or the sub thermistor detects overheating (hardware circuit detection).
0002
The sub thermistor detects about 295°C or higher.
E002
0000
The temperature of the fixing film is as follows:
· has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
· has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
· has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
E003
0000
The main thermistor reading is lower than 140°C when paper is moved.
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
E010
0000
After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec.
how to solve error code E000000 - 0001
The temperature of the fixing assembly is abnormally high.
While startup control is under way, the reading of the main thermistor is less than 30 deg C continuously for 200 msec or more 1 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 70 deg C continuously for 200 msec or more 2 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 120 deg C continuously for 200 msec 6 sec after the start of power supply. The startup control does not end 30 sec after the start of power supply.
Nov 21, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
how to solve error E000 0000
E000 0000 = The reading of the main thermistor does not reach 30 degrees C 1 sec after the main power switch is turned on. Or, it does not reach 70 degrees C 2 sec thereafter.
In other words, the fuser, or the section that heats up to melt the toner on the paper, is not heating up.
Jun 19, 2014 | Canon imageRUNNER 6020 Copier
canon IR 2200 manual
Canon iR2200 / iR2800 / iR3300
Некоторые ошибки зависят от того, какая опция установлена: например, ошибки E514 для Saddle Finisher-G1 и Finisher-J1 имеют разные причины.
Код ошибки Субкод Описание E000 0000 The reading of the main thermistor does not reach 30oC 1 sec after the main power switch is turned on. Or, it does not reach 70oC 2 sec thereafter E001 0000 The main thermistor detects 250oC or higher 0001 The main thermistor or the sub thermistor detects overheating (hardware circuit detection) 0002 The sub thermistor detects about 295oC or higher E002 0000 The temperature of the fixing film is as follows:
  • has exceeded 100oC, but does not reach 115oC within 1 sec thereafter.
  • has exceeded 140oC, but does not reach 150oC within 1 sec thereafter.
  • has exceeded 160oC, but does not reach 165oC within 1 sec thereafter
  • E003 0000 The main thermistor reading is lower than 140oC when paper is moved 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 An error in the rotation of the fixing film is detected.
    The reading of the main thermistor is 100oC or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven E010 0000 After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec
    Sep 13, 2009 | Office Equipment & Supplies
    436 people viewed this tip
    k24674
    jasbo
    jasbo
