Tip & How-To about Televison & Video
Tips that may help you determinate what is the main problem of your TV
Hello to all well here are some tips that may help you determinate what is the main problem of your T.V'S
1- If you put you hand on the top of your tv and you feel vibrations in your hand when you turn the on that meas that you could have a color wheel problem.
2- If you screen on your TV is with weird spots of color and you don't have any pic only voice could be the digital board.
I hope this tips help you to determinate what is the issue of your TV.
Good Luck
Ness
Televison & Video Logo
AMANA DRYER MOD # P NGD 7200TW FRONT LOAD ABOUT 1 1/2 - 2YRS OLD NOT GETTING HOT WHEN TURNED ON HOW DO I OPEN FRONT PANEL TO CHECK IGNITOR AND SENSORS
To open that dryer ya need to first remove the top by removing the screws in the rear of it,then remove the control panel...behind the control panel are screws that hold the front panel to the cabinet.
this tip i wrote will help ya to determine why its not heating...after disconnecting the front panel it can be letf connected to run the dryer to see whats happening as far as the igniter not coming on or whatnot
Here is that tip http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 10, 2011 | Amana ALG230RAW Gas Dryer
Wife has Kenmore 385.12314. Regular use. Normally cleaned and oiled. Needle goes down, but bobbin thread doesn't catch. Needle at bottom of stroke and "half moon" is on top, needle crosses half moon about 1/3 of way in from left tip.
Make sure the needle is in the machine correctly- all theway up into the needle bar, make sure that it is threaded correctly, etc. Ifthis all checks out ok, take the bobbin case out of the machine. There are twoears on either side of the bobbin case- turn the left one to the left and theright one to the right. Remove the silver ring, and inspect the piece of metalthat the ring came off of (looks like a circle with the top cut off). You haveto locate the hook which is the piece that looks like a half moon inside thebig round metal piece. Locate the tip of it, turn the hand wheel toward youuntil the needle is in the lowest position, at this point the tip of the hookshould be flush with top of the left side of the cut off circle. If this is notso, your machine needs to be re-timed. If that is the case, I would need to seea picture of the bottom of the machine so that I am able to determine whatneeds adjusting. Make sure you're turning the hand wheel in the proper direction-- the proper direction isthe one that will feed fabric forward under the presser foot.
Make sure the needle is facing in the correct direction -- stitches don't form,or skip badly when the needle is turned around.
Put the bobbin in the bobbin case (right way around) leaving a 2-3" tail.
Thread the top of the machine correctly, leaving a 3-4" tail afterthreading the needle.
Hang on to the end of the upper thread, and use the hand wheel to drop theneedle... continue to turn the hand wheel to raise the needle. Pull on the endof the needle thread and a loop of bobbin thread should come up.
Hold BOTH threads behind the presser foot when starting a seam to preventthread jams.
Hope this will help you. Good Luck.
Aug 17, 2011 | Vacuums
A metal object about the size of a matchead has gone through the top end distroying cylinder and piston and head.Cant find the source?
Put a magnet onthe piece and determine if its magnetic or not.
This will help you determine where it may have come from.
Could you have lost the tip off your plug
Oct 29, 2010 | Yamaha YZ 250 Motorcycles
Hello. We have a Whirlpool Ultimate Care Heavy
yes you r. lol
the agit. dogs need replaced look in your phone book 4 a dealer near you to get this part you need. remove softner despenser and inner cap then you will need to remove bolt 7/16th or 3/8th after removing bolt pull up on agit.it is 2 pc if it all comes out as one pc. ok you need to stand on lower 1/2 and pull up you now have the top pc in your hands. you will see some type of cup that holds in the dogs remove by flipping up side down install new parts and put back togther a small tip use the bolt
to put cup back in when you are ready to put back together put top pc of agit. over cup up side down you will need to line up with 2 or 4 ears on bottom pc. it should click now reinstalle sound hard but very easy just keep preassur on dog cup at all time with bolt and socket have fun
Feb 10, 2010 | Whirlpool Washing Machines
I get a dimension error on my screen from my matrix
You cannot calculate the inverse of an arbitrary matrix. It must be a square matrix (nxn) with non zero determinant. Make sure dimensions m and n are equal. (2x2), (3x3)
To calculate its determinant [Shift][MATRIX] [7:det] [SHIFT][MATRIX][3:MatA] close the right parenthesis and [=].
If determinant is different from zero then you can calculate its inverse.
If matrix MatA has already been defined, you calculate its inverse as follows;
[SHIFT][MATRIX][3:MatA] [X^-1][=]. Use the X to -1 power , the one under [MODE].
For well-behaved matrices you calculate the inverse directly without worrying about the determinant.
Hope it helps.
Apr 16, 2009 | Casio FX-115ES Scientific Calculator
181 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
