Tip & How-To about Computers & Internet
How to find fix and update driver's.
If you are having problems locating a driver or device problem below is instructions on how to search and update you device driver with windows XP
open Start>Run enter devmgmt.msc>ok
+Expand and Rigth click on the device you are having problems with
and select update driver
allow windows to search online
select>install the softwear automatically
windows will look for the best driver for your device
To reset back to your previas driver
Rigth click the device and select properts
select the driver tab>roll back driver
any faults will be high lited yellow(!)
Computers & Internet Logo
problem with dell studio 1737 downgraded from vista to xp
As per the DELL web site there is no driver provided for Windows XP , Check witht DELL technical support.
Nov 03, 2009 | ASUS P5GC-MX/1333 Motherboard
could not find media device
Updating audio drivers Select one of the options below to locate the available audio drivers if you already changed the operating system and you are experiencing sound problems.
  • Go to the HP Drivers and Downloads page and search for updated drivers for your model. Be sure to select the correct operating system.
Or download Conexant High-Definition Audio Driver » ftp://ftp.hp.com/pub/softpaq/sp40501-41000/sp40762.exe
  • If the computer is upgraded to Vista, use HP Update to scan for updated drivers. To use HP Update, click Start , All Programs , HP , HP Update , and then follow the on-screen instructions.
  • If HP has not released specific audio drivers for your operating system, use the Microsoft Windows Update utility, or search the Microsoft web site for generic drivers for Vista. To use Windows Update, click Start , type update into the search field, select Windows Update from the list when it becomes available, click Check for updates , and then install any available updates.
For more information please visit :-
Using the HP Instant Support Professional Edition (ISPE)
Aug 05, 2009 | Microsoft Windows XP Professional With...
BCCode Error
CAUSE loadTOCNode(1, 'cause'); You may receive this error message when Windows attempts to use device drivers that are incompatible with Windows XP. uparrow.gifBack to the top
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this issue, verify that each device in your computer uses a driver that is compatible with Windows XP. To do so, follow these steps: 1. Click Start, right-click My Computer, and then click Properties. 2. In the System Properties dialog box, click the Hardware tab, and then click Device Manager. 3. For each device, use the following steps to verify that it is using a Windows XP-compatible driver.NOTE: To narrow down the search, begin with devices that have been disabled. A disabled device has its icon overlaid with a red X.
a. Double-click the device name to open the device Properties dialog box, and then click the Driver tab. b. Examine the driver version. All Windows XP drivers should be version 5.1.2600 or later. c. If you are not sure about the displayed version, examine the driver date. Drivers created before the year 2001 may not be compatible with Windows XP. 4. After you identify an outdated device driver that may be causing the problem, follow these steps to update the driver: a. Insert your Windows XP CD into the CD-ROM drive. If Setup starts automatically, quit it. b. In the device Properties dialog box, click Update Driver to start the Hardware Update Wizard. c. Click Install from a list or specific location (Advanced), and then click Next. d. Click to select the Include this location in the search box, and then type your CD-ROM drive letter in the space below. For example, type D:. e. Click Next. f. Follow the on-screen instructions to finish updating the driver. 5. Restart your computer if prompted.
Sep 20, 2008 | Microsoft Windows XP Professional
communication port
u need to install the drivers from the blue cd that says dell drivers and utilities
Apr 11, 2008 | Dell Inspiron 6400 Notebook
220 people viewed this tip
David Payne
David Payne
