Tip & How-To about Televison & Video
Dont Make This Mistake With Your Lcd Tv Set!
Ok lets just say you wake up one morning and the screen on your lcd tv set does not want to turn on, outside it is cold.The tv set turns on but the screen does not, turn off the tv set leave it like that for acouple of seconds turn it back on and your tv set should be up and working, if for some reason this is not the case try it one more time just to see what happens.After trying the above suggestion your tv set does not work than the problem is the backlight, Thank You.
Televison & Video Logo
Channel Memory
Don't use EZ scan,reset it to Factory Setting.Use Ch.set up go through the whhole process every channels should be there.
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
We have a Dynex 19" television. We use the "timer" function as a wake-up alarm in the morning. The set should turn on at 5:55 AM. Recently the unit stopped turning on automatically. I checked all the settings and they are correct (clock has correct time of day, timer set to correct times and is activated. Have also had unit turn on 1 hour earlier than set time. Is there a fix?
After cussing at the thing for a while to get its attention,
I thought the problem over and fixed it as follows:
I went into the setup menu and selected the "reset default option. The set went to blue screen. The next step was to rescan the channels. Then in the time setup menu I turned off the automatic time update. So far have not had any more problems.
Aug 03, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
"TV, turns it's self on"
Yeah Go Into Your Options Menu And Find The Wake Up See If Its Set To Turn Itself Off. I Use This When I Go On Vacation So People Will Hear The T.v On And Off At Intervals.
Jan 05, 2009 | Televison & Video
"Alarm" wake up
Not all TVs have this function. Have a brand new HP LCD 42" TV, doesn't have the function available.
Jul 07, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
213 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
