Tip & How-To about Sport & Outdoor - Others
Check Brake Light Bulbs: All cars have three brake light bulbs that create the brake light illumination affect. If the lower two bulbs fail no lower brake light operation will occur. I know what you're thinking, you might say two brake lights at once? But in reality one brake light went out at a time and you did not notice. People only tend to notice something when they almost run into the back of your car to help persuade them to inform you the brake lights aren't working. Remove either of the brake light bulbs to confirm the bulb is ok or burned. After the bulb has been removed inspect the filament and replace if failed. If the brake light bulbs are ok continue to the next step. Checking the Turn Signal Switch: Most American cars are designed to have the brake light switch wiring intergraded into the turn signal switch. Because the brake light bulb and the turn signal bulb are one and the same the turn signal switch interrupts the brake light circuit and installs the blinker signal circuit when the turn signal switch is activated. If this switch fails it will not allow the brake light signal through to the brake light wiring. To test for this condition a car repair manual is needed to test incoming and outgoing electrical current. If brake light switch power is present at the turn signal switch but not at any outgoing brake light wires the turn signal switch has probably failed.
Sport & Outdoor - Others Logo
I have a 91 ford f150 and the brake lights wont work and the rear right blinker is dim. Can you help me?
Check System Fuse - A fuse is used to protect the brake light circuit from amperage overload. If the fuse has failed it will not allow the electrical current to continue to the brake lights. To check the fuse, first locate the brake light system fuse in the fuse panel which is either under the dash or under the hood in the power distribution center. Connect the test light to a ground like an engine or dash bracket and turn the ignition key to the "on" position. Using the test light probe both sides of the fuse. If the test light illuminates on both sides the fuse is okay continue onto the next step. If one side of the fuse illuminates the fuse has failed and needs to be replaced. If the fuse fails as soon as it is replaced or when you apply the brake pedal the brake light electrical circuit is shorted to ground. Rarely a system short can occur, a car repair manual is needed to find the wiring schematic for the brake light circuit. Once the brake light wiring has been located inspect and repair as needed.
Check Brake Light Bulbs - All cars have three brake light bulbs that create the brake light illumination affect. If all of these brake light bulbs fail no brake light operation will occur. I know what you're thinking, you might say all three brake lights at once? But in reality one brake light went out at a time and you did not notice. People only tend to notice something when they almost run into the back of your car to help persuade them to inform you the brake lights aren't working. Remove any of the brake light bulbs to confirm the bulb is okay or burned. After the bulb has been removed inspect the filament and replace if failed. If the brake light bulbs are okay continue to the next step.
Checking the Brake Light Switch - A control switch is used to connect the brake light electrical circuit. This switch is located near the brake pedal lever. Basic switches have just two wires, power in and power out to the turn signal switch. Use a test light that is grounded and with the key in the "on" position test for power at one side (wire) of the switch, then press the brake pedal while testing the opposite side (wire). It should illuminate the test light, if electrical power is connected through the switch go to the next step. If no power is detected through the switch the brake light switch has failed and replacement is required. If your car is equipped with more than two wires integrated into the brake light switch a car repair manual is needed to locate the proper brake light circuit wiring.
Nov 05, 2011 | 1991 Ford F150
when headlight are on and hit the beake pedal only the 3rd brake light comes on the rest are stuck . When i release brake pedal it seems like i am driving with my brake light on . but my headlight off every thing is fine brake light work
It may sound silly, but check your brake light bulbs to see if they have been installed incorrectly. Brake light bulbs have two filaments, one for tail light, and a brighter one for brake lights. On some cars if the bulb is installed wrong, the brighter filament will stay on for tail lights. The only other thing I can think of is the wrong bulbs have been installed.
Dec 25, 2010 | Toyota Camry Cars & Trucks
brake lights do not work All bulbs have been replaced.
Troubleshooting Procedures - Read Completely Before Beginning
(American Car) All Brake Lights Not Working
  • Check System Fuse: A fuse is used to protect the brake light circuit from amperage overload. If the fuse has failed it will not allow the electrical current to continue to the brake lights. To check the fuse, first locate the brake light system fuse in the fuse panel which is either under the dash or under the hood in the power distribution center. Connect the test light to a ground like an engine or dash bracket and turn the ignition key to the "on" position. Using the test light probe both sides of the fuse. If the test light illuminates on both sides the fuse is ok continue onto the next step. If one side of the fuse illuminates the fuse has failed and needs to be replaced. If the fuse fails as soon as it is replaced or when you apply the brake pedal the brake light electrical circuit is shorted to ground. Rarely a system short can occur, a car repair manual is needed to find the wiring schematic for the brake light circuit. Once the brake light wiring has been located inspect and repair as needed.
  • Check Brake Light Bulbs: All cars have three brake light bulbs that create the brake light illumination affect. If all of these brake light bulbs fail no brake light operation will occur. I know what you're thinking, you might say all three brake lights at once? But in reality one brake light went out at a time and you did not notice. People only tend to notice something when they almost run into the back of your car to help persuade them to inform you the brake lights aren't working. Remove any of the brake light bulbs to confirm the bulb is ok or burned. After the bulb has been removed inspect the filament and replace if failed. If the brake light bulbs are ok continue to the next step.
  • Checking the Brake Light Switch: A control switch is used to connect the brake light electrical circuit. This switch is located near the brake pedal lever. Basic switches have just two wires, power in and power out to the turn signal switch. Use a test light that is grounded and with the key in the "on" position test for power at one side (wire) of the switch, then press the brake pedal while testing the opposite side (wire). It should illuminate the test light, if electrical power is connected through the switch go to the next step. If no power is detected through the switch the brake light switch has failed and replacement is required. If your car is equipped with more than two wires integrated into the brake light switch a car repair manual is needed to locate the proper brake light circuit wiring.
Jul 07, 2009 | 2000 Jeep Grand Cherokee
390 people viewed this tip
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
