Tip & How-To about Coffee Makers & Espresso Machines
Superautomatic does not make coffee. Wet grounds & pump runs a long time, then ventilate.
You have a plugged brew head or bent gate valve. I can help with the brew head but not the gate valve.
Remove the brew unit. Holding the handle, the top left side is the brew head. There is an outlet pipe that is either to the front or back. 2 screws hold it to the top. Remove the 2 screws while holding the manifold ( pipe assembly). Once they are removed, lift the assembly off (be careful, there is an O-ring, spring and at the end, and a black rubber disk or ball that you can loose.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON'T use the key to install the screen, use your fingers.
Once the screen is out look at where the screen was. There are 2 holes. A big one in the center and a small one to the side.
With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the ball in first. Then the spring, small end first on the ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the direction it came off. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
Coffee Makers & Espresso Machines Logo
i pulled the brewing unit apart to give a thorough clean and im left with alittle plastic ball can you please tell me where it goes my coffee is very watery at the moment so im assuming this ball restricts the flow through the unit thank you
Hi
Read carefully, your answer is towards the bottom.
Aug 21, 2011 | Saeco Royal Cappuccino Espresso Machine
After using oily coffee beans the machine drops one drop at a time how do I clean the coffee grinder and drip system alos it says after the rinsing cycle 'ventilate' how do I ventilate.
Hi
The ventilate is just opening the steam valve for just water. Don't push the button for steam. Your grinder needs to be a little coarser. Turn the big know in the bean hopper to a larger #, about 2 to 4
# higher.
You need to clean the brew head in the brew unit.
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front, towards the door (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring with a black seal (don’t loose it or your out of luck).
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON’T use the key to install the screen, use your fingers...
Once the screen is out, look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
With the brew unit upside down over the towel insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Then the spring with black seal down.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the handle side. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Install in machine and test
Jun 26, 2010 | Solis Master 5000 Espresso Machine
The machine appears to function OK but then does not dispense coffee !! Have cleaned the machine and am unable to find any blockages in the system. ???
Hi
You might need a brew head cleaning. It can get pluged with coffee residue and oils. But you could also have a bent injector valve or gate valve. But I would try this first.
Remove the brew unit. Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON’T use the key to install the screen, use your fingers.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
Jun 09, 2010 | Saeco Vienna SuperAutomatica Coffee...
I keep having to unplug the screen in the coffee press. Can I adjust the tamping pessure down?
Hi
Have you ever cleaned the brew head completely? There is a spot that will plug up. Screens will cake on the back side if they are not cleaned, but the holes don't plug up much.
Hi
If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head.
If it run normally, your grind is to fine. Push the grinder lever to a larger number.
If it still dribbles, remove the brew unit (behind the door)
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the backside towards the machine (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (becareful, there is an O-ring, spring and inside a crystal ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the crystal ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers.....
Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this
Dec 30, 2009 | Saeco Royal Professional Espresso Machine
622 people viewed this tip
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
