Tip & How-To about Office Equipment & Supplies
Ways to avoid getting clogged nozzles on your epson printers.
Three common ways that the printhead on Epson inkjet printers clog up.
1. Generic Ink is used. The problem with generic ink, is not only the chemical composition is different; thus not getting the best quality prints, but the viscosity. I have 2 different types of issues. If the ink is too thin, then the ink will seep through the casing and burn the printhead board. If the ink is too thick, it will start to build up in the tubes of the printhead until it clogs up the tube. It very similar to cholesterol. The more greasy foods you eat, the smaller the passage way in the arteries become. Once the nozzle clogs up, the ink can not flow anymore, dries up and no ink comes out.
2. Not using the printer a long time. If you don't use your printer more than 3 weeks (+/- a week or so), there is a good chance the ink in the printhead will dry up. Similar to milk in the fridge. I am sure you dont want to drink milk thats been in the fridge for more than a month. Usually the ink near the nozzles dry and do not allow the printhead to spit out the ink.
3. Lastly, we see printers with clogged printhead when users print big jobs just after the printer reports low ink. When this happens, the ink in the resovoire (sp?) will empty and then air will be sucked into the nozzles. As soon as oxygen and the ink mix, the process of drying ink begins to form. Air pockets and dried up ink stop the process of flow to the paper.
The only option usually is to take it to a service center, they will inject into the nozzles a type of acid that eats up the dried up ink. It works about 65-70% of the time. Also some of the liquid is put into the cleaning station that goes below the printhead when it is parked.
thank you
Generic Ink cartridge causing printhead errors
It's not a guarantee that the remanufactured cartridges will work the same way as our cartridges. Remanufactured cartridges also voids the warranty of your printer.
For best results, always use genuine Lexmark cartridges. We do have a Smart Supply program where you will always get 10% off each cartridge purchase and free shipping every time. Check here for more info: http://bit.ly/HNG1M9
Apr 23, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
epson wont recognize black refill cartridge.
I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunately, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps.
Jun 26, 2011 | Office Equipment & Supplies
Does not reconize non epson ink cartridge. I remove and reinstalled and it printed but now its back to not reconize cartridge.
You did not say if you were using "New-Epson Ink Cartridges", or actually using "Non-Epson Ink Cartridges" [Generic or Third-Party ink cartridges] in your printer. I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunatly, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps...Good Luck!
Jun 09, 2010 | Epson CX8400 All-In-One InkJet Printer
Replaced HP 88 Printheads, still receive same
You either got a defective printhead or you are using generic inks, HP got real smart and added chemicals to their ink, if the printer doesn't see the right chemical makeup it will give that error and you need to flush the printhead and the pump and hoses with HP ink or the error will stay.
Jan 13, 2010 | HP Officejet Pro K550dtn InkJet Printer
Hi. Printer isn't working, paper comes out blank.
Most likely the printhead is clogged. Another possibility is that the cleaning station does not work. 3 ways the printhead can clog,
1. Using Generic Ink
2. Not using the printer for a long time
3. Print a large print job after the ink indicator says the inks are running low.
You are better off replacing the unit than trying to get the printhead unclogged. Cost is usually around $40 and is only a 65% chance it willwork.
thanks
Dec 17, 2009 | Epson CX4600 Stylus Color All-In-One...
295 people viewed this tip
k24674
