Tip & How-To about Televison & Video
How to Unlock Your Apex TV When Screen is Locked
If you find that your Apex TV is showing a blank screen with a red key on the bottom left then the Screen Lock otherwise known as Child Lock or Parental Control has been accidentally activated and your TV will not respond to commands from the remote control.
To resolve this and reactivate the TV simply press the (function or F) button and hold down the mute button on the remote at the same time for around 10 seconds. This will unlock the screen and allow you to view the channel as desired.
If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or to reset any preset rating levels.
This extract is taken from an Apex Manual specific to the child lock function;
The Childlock function is designed to prevent chiIdren from watching TV. To activate: HoId down the F button and then press the MUTE button until the symboI “ ” appears on the screen. The TV will enter the Childlock mode.
Except for the “ ” symbol the screen becomes blue or black . To unlock the TV hoId down the F button and then press the MUTE button again.
Please Note:
The Childlock can be set or cancelIed only by the remote controI. After setting Childlock, secure the remote control in a safe place.
If this Tip has helped please do take time to indicate this by using the rating buttons on the page below.
Many thanks for using FixYa.
Televison & Video Logo
child lock on and do not know how to disengage
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the function or F button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Apr 09, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Jul 20, 2008 | Apex Digital AT2702 27" TV
blue screen and a small red key
worked just fine for me! thanks!!! 'function' key is in the top left hand corner
Mar 16, 2008 | Apex Digital AT2402 24" TV
apex tv pf2030 child lock
I'm afraid you will need the original remote control hand unit folks. Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Jan 19, 2008 | Apex Digital PF2025 20" TV
Child Locked the TV
* If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. * If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels. * If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688. One of the above methods should get you past the lock. If so, I would take the opportunity to disable the lock in the TV's menu so this doesn't happen again. If this still doesn't work, you can call Apex Customer Support at (800)880-1227.
Oct 24, 2006 | Apex Digital GT1417DV 14 in. TV/DVD Combo
3,867 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
