Tip & How-To about Dolphin Maytronics Diagnostic Robot Cleaner
Your Dolphin pool cleaner wont start up...
A common problem, especially with 'newer' Maytronics Dolphin brand pool cleaners is that you put the unit in the pool, or even try to turn it on after a cleaning cycle while it is still in the pool, and to that point it has worked fine. You turn the power supply on and nothing happens. You turn it off and back on and still nothing. You leave it, even over night, same thing. What do you do?
While I cannot tell you why it does this (we have a theory but can not confirm it) what usually works is to follow these steps...
1) Unplug everything. Unplug the power supply from the outlet and the Dolphin from the power supply.
2) Let the whole thing sit a couple of minutes (we want to allow any capacitors to discharge).
3) Be sure the Dolphin is out of the water and sitting upside-down on a level surface (Tracks pointing skyward).
4) Reconnect the Dolphin to the power supply and the power supply to the outlet.
5) With the Dolphin still out of the water, perform a self-test. Simply turn on the Dolphin. Within about 15 seconds it should begin to move. The tracks will spin in both directions with and without the impeller motor running at the same time. It is not unusual for the tracks to rotate at different speeds during this test. The test will last for 30 - 45 seconds or so. If it goes on indefinitely, turn it off and contact us for further direction.
6) Assuming the unit has now worked to this point, you should be able to put it back in the water and it will return to normal operation from this point on.
If it still won't run; it runs a few moments and quits the self-test; or runs continuously, contact us thru the Dolphin service form along the bottom of our home page at www.arrowpools.net.
Dolphin Maytronics  Diagnostic Robot Cleaner Logo
Goes to wall and turns itself over. It is clean.
Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ...
? 3:44
www.youtube.com/watch?v=-x8hwghv8BE
Apr 4, 2012 - Uploaded by Swimming Pool Tips, Reviews & How To -MrDgvb1 Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ... Solar Breeze: The Robotic Solar-Powered Pool Cleaner Review: http://youtu.be/jzWfClbOnIc ... Pentair Kreepy Krauly Legend Review, Troubleshooting & Tips:
Aug 08, 2015 | Dolphin Maytronics Diagnostic Robot...
how do i put filter bag on dolphin
Here is a copy of the users manual for these pool cleaners. Page 7 has step by step instructions for putting the filter bag back on after washing it. There is also a detailed diagram on the last page that shows how the whole cleaner fits together. I think this should help you out.
http://www.backyardcitypools.com/images/smartpool/Dolphin-3002-Manual.pdf
Jul 20, 2011 | Dolphin Maytronics Diagnostic Robot...
need instruction manual for dolphin unit - the dolphin unit climbs walls but doesnt clean the bottom of the inground pool
If you need one for the dynamic model it is here.
Of not pick your model from the list and go to more info...from there you can select the manual.
You can also explore the Maytronics website for additional info or try our FAQ section at www.arrowpools.net.
John
Jun 05, 2011 | Dolphin Dynamic In - Ground Pool Cleaner
cleaner wont reverse.will try to climbe out of pool wont reverse. this is a dolphin superkleen.
Contact Maytronics, manufacturer of the Dolphin cleaners, for troubleshooting assistance and referrals to regional service centers directly at www.maytronicsus.com or 1-888-DOLPHIN.
John
May 23, 2011 | Dolphin Maytronics Diagnostic Robot...
16,132 people viewed this tip
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
