Tip & How-To about Computers & Internet
What do I do when my motherboard won't boot
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a Dead Board
Computers & Internet Logo
TURNING PC ON
Hi welshbry,
If you have extra parts your in a good position to attempt detective work.
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a Dead Board.
Good Luck,
Mark
Dec 21, 2009 | Gigabyte Computers & Internet
When turning on the cpu, there are no beeps on boot up?
Hi .
Good Luck and don't forget to leave a rating.
Thanks
Mark
Dec 19, 2009 | Soyo P4X400 Dragon Ultra Motherboard
Hello, i seem to have the same problem others have. my gateway GT5628 won't start. i get the right volt readings with the power supply disconnected from everything. but when it's connected i get no fan or any thing. i am getting grounded readings at any point on the mother board i check, is that right?
Hi jr_51,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Thanks
Mark
Nov 14, 2009 | Gateway Computers & Internet
LED board is on but failure to start.
Hi elumrich,
Good Luck
Mark
Nov 11, 2009 | ASUS P5P800-VM Motherboard
only red light appear on the cpu
Good Luck
Oct 14, 2009 | Biostar K8M800-M7A Motherboard
132 people viewed this tip
David Payne
David Payne
