Tip & How-To about Computers & Internet
HOW TO UPDATE BIOS
WHEN YOUR SYSTEM HAS ANY PROBLEM LIKE RESTART,BLUE SCREEN .JUST UPDATE YOUR BIOS BY DOWNLOADING LATEST VERSION FROM INTERNET.& INSTALL IT FOLLOW ALL STEPS & ENJOY.......
Computers & Internet Logo
how to update bios
To find the current BIOS version, follow the steps below:
  1. Restart the computer and enter the BIOS screen by pressing the F1 or F10 key at the first screen.
  2. Write down the BIOS revision number from the Main page. You will use this number to see if HP has a later version available.
    1. Go to the HP Software download page
    2. If you are presented with a page to enter your model number, type in your model number. For example, Pavilion p6230f or TouchSmart 600-1050uk.
    3. Select the version of Windows the computer is using.
    4. Click the BIOS link.
      • If a BIOS update is not listed, HP does not have a BIOS update posted for your computer at this time.
      • If there are several BIOS updates available for different motherboard names, you need to find out what motherboard is installed in your computer. To do this, turn off the power to the computer, remove the side panel, and read the name printed on the motherboard. The name of the motherboard should match or be similar to the name of the download link.
      • If a BIOS update is listed, continue to the next step to download and install the BIOS update.
        Click the download link. The instructions for downloading and installing BIOS updates vary. For most computers with Windows XP, download the file, open it and follow the on-screen instructions. For many computers before Windows XP, save the downloaded file to the hard drive, insert a formatted disk, open the downloaded file to copy the BIOS files to the disk, and then restart the computer with the disk still in the drive. The instructions on the download page may be different so carefully read and follow the instructions on the download page and in the installation setup screens. If a 251 or CMOS Checksum error occurs after installing the BIOS update, perform the following steps:
        2. Press the F5 key to load the default BIOS configuration.
        3. Select YES by using the arrow keys, and then press Enter .
        4. Press the F10 key to save the settings and exit.
        5. Select YES by using the arrow keys, and then press Enter .
        When the BIOS update is complete, the new BIOS revision number is updated on the Main BIOS screen.
Feb 28, 2011 | Compaq Presario 700 470024-192 Notebook
how to update version of psp
There are two ways to do this 1.For the latest version without having to use the internet,you need to buy one of the latest games then when you try to start it if your version is not high enough it will say ''An update is needed.Update now?'' say yes and follow it's given instructions.
2.You need the internet for this one.
Go to settings from the PSP homescreen,go to System Update you are given two choices Update via Internet and Update via Media Storage,choose Update via Internet it asks you a few questions on whether you want to update say yes to them all,then it should start downloading,when it has finished downloading (It might just ask you whether you want to install the update when it finishes downloading) go back to System Update and this time choose Update via Media Storage,it gives you some instructions and asks you to accept the license agreement then it will start installing,after it is installed go to games and Memory Stick and delete the update.
Good luck.
Sep 23, 2010 | Sony PlayStation Portable (PSP) Console
desktop hp Product Number P6402A
Step 1: Find the current BIOS version number
  1. Turn ON your pc. When the first screen appears, press F1 to enter the BIOS Setup. On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
  2. The BIOS revision number is listed on the Main menu. Write down the current BIOS version that is listed.
  3. To exit the BIOS setup screen, press F10 , select Yes , and then press the Enter key.
Step 2: Check the Drivers and Downloads page for BIOS or ROM updates
  1. Go to http://h10025.www1.hp.com/ewfrf/wc/softwareRedirector?lc=en&dlc=en&cc=us&product=67009&docname=c00007682 enter the model of the PC (for example, Presario 5002US or Pavilion a518d), and click the download button.
  2. Click the link for the PC Operating System (like Windows XP).
  3. Try to find the BIOS update listed under the heading, BIOS , BIOS- System , or RomPaq.
    NOTE: The term "Rompaq" refers to BIOS updates for Compaq Presario PCs prior to 2002.
  • If a BIOS update is not listed, HP does not have a BIOS update posted for your PC at this time.
  • If there are several BIOS updates available for different motherboard names, you need to find out what motherboard is installed in your PC. This can be done by turning off the power to the PC, removing the side panel, and reading the name that is printed on the motherboard. The name of your motherboard should match or be similar to the name of the download link.
  • If a BIOS update is listed, proceed to the next step to download and install the BIOS update.
Step 3: Download and install the BIOS update
  1. Click the download link. The instructions for downloading and installing BIOS updates vary.
  • For most PCs with Windows XP, download the file, open it and follow the on-screen instructions.
  • For many PCs before Windows XP, save the downloaded file to the hard drive, insert a formatted disk, open the downloaded file to copy the BIOS files to the disk, and then restart the computer with the disk still in the drive.
  • The instructions on the download page may be different so carefully read and follow the instructions on the download page and in the installation setup screens.
  1. If a 251 or CMOS Checksum error occurs after installing the BIOS update, perform the following steps:
  2. Restart the PC and enter the BIOS screen by pressing the F1 or F10 key at the first screen.
  3. Press the F5 key to load the default BIOS configuration.
  4. Select YES by using the arrow keys, and then press Enter .
  5. Press the F10 key to save the settings and exit.
  6. Select YES by using the arrow keys, and then press Enter .
Please rate this solution. Thank you.
Feb 01, 2009 | Computers & Internet
Blank screen
See lets isolate the fault...As u have checked the monitor cable is fine,the monitor is fine and the video card is also fine..I believe you have tried these 3 components on another pc and it has worked fine..Rit? Now the last thing is first download the latest BIOS update (Find the current BIOS version number,Press F1 when Pc starts,on Main menu u can find BIOS number ; From ur other PC,check the Internet for BIOS or ROM updates keeping in mind the BIOS version number u have noted down ;Download and install the BIOS updates to a CD ..copy the BIOS files to the hard disk, and then restart the computer with the CD still in the drive...That should work..2ndly,I would update my video card driver from the internet using my other computer in the same way..
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
220 people viewed this tip
David Payne
David Payne
