Tip & How-To about Computers & Internet
Is your FOLDER OPTIONS missing..? Here's a Solution
Open Run and then type "gpedit.msc".
Now goto User Configuration > Administrative templates > Windows Component > Windows Explorer.
Click on Windows Explorer you will find the 3rd option on the right side of screen "Removes the Folder Option menu item from the Tools menu"
Just check it, if it is not configured then change it to enable by double clicking on it and after applying again set it to not configured.
I hopes that you will find the option after restarting windows.
NOTE : This usually occurs if the pc is infected, Make sure to use a good updated Antivirus.
Computers & Internet Logo
How do i turn off inprivate browsing
Hello angel_a_38,
You can simply close all in-private browser windows. When you launch the Internet Explorer application it should be in normal browsing mode.
Hope this helps! Please give 4 thumbs up if it does!
Jul 06, 2011 | Microsoft Internet Explorer 8
my dvd drive cannot read or open the file
hi ophelia1)it was something to do with installing updates for it? 2)By cleaning heads /lence ,we can solve this problem some time. 3)Go to your run command and type (start.....Run.....) type gpedit.msc
Go to User configuration/Administrative templates/Windows components/Windows explorer
On the right pane, double click on "Remove CD burning features" tick the enabled button, then OK.
Reboot or logoff/logon to apply.
If your vista version does not have the gpedit function, do the following.
Open regedit, go to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
In the right pane, if it does not already exist, create a new 32-bit DWORD value. Name the new value as NoCDBurning, and assign the value data to 1
May 22, 2010 | Computers & Internet
my system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
I have purchased a cannon multyPass c5000 and have windows XP when I try to install the dialog box sayd the CD does not have a digital signature. Is there any way to by pass this problem. I suspect it is because this product is compatable with windows 95.
Go to your run command and type (start.....Run.....) type gpedit.msc Go to User configuration/Administrative templates/Windows components/Windows explorer On the right pane, double click on "Remove CD burning features" tick the enabled button, then OK.
Reboot the system
Dec 14, 2008 | Office Equipment & Supplies
Function key problem with compaq nx6120
-Click on run from start menu
-Type gpedit.msc
-User Configuration
-Administrative templates\Windows Components\Windows Explorer
-Double click "Turn off Windows +X hotkeys"
- Try the different settings (i.e. not configured, disabled, etc) to see if any of these solve the problem
May 10, 2008 | HP Compaq nc6000 Notebook
186 people viewed this tip
David Payne
David Payne
