Tip & How-To about Microsoft Windows Vista Ultimate Edition
How To Create Bootable USB To Install Windows Vista
His tutorial will help you in creating a bootable USB drive ofWindows Vista which you can use to install Vista in any system. Itmight become very useful when you don't have access to DVD drive.
Use the tutorial available Here .
or
Do it using COMMAND PROMPT
1. First format your USB drive in NTFS file system. You can do it byattaching your USB drive to your system and then format it from MyComputer window.
2. Now open Command Prompt window from Start menu. Right-click onCommand Prompt entry in start menu and select "Run as administrator"option.
3. Now type diskpart in Command Prompt window and press Enter. It'll launch DiskPart program
4. Now provide following command:
list volume
It'll show a list of all drives in your system. Look for your USB driveentry. As in the below screenshot, the USB drive is "G" which you candetermine from its "Type" entry.
Now you have to select the USB drive volume by providing select volumeno. command. Since in our case volume no. of USB drive is "Volume 4",the command would be:
select volume 4
Now we have to make this drive active. So provide active command:
active
Now exit from DiskPart using exit command.
5. Now we need to create Boot sector on USB drive. We'll use"bootsect.exe" utility for this task. You can find this utility inWindows Vista setup disk. It'll be present in "Boot" directory.
Now provide following command in Command Prompt:
bootsect /nt60 G:
Here G is drive letter of USB drive. Replace it with the correct driveletter if your system has some other letter for USB drive.
6. At last, copy all files/folders from Vista Setup DVD to your USB drive and you have done.
Now you can boot using your USB drive and can install Windows Vista in any system.
Microsoft Windows Vista Ultimate Edition Logo
boot flash drive
Download the HP Format Tool and install it. Get your boot disk or the downloadable files and copy/extract them to a folder on your HD. Make sure anything on your USB Drive is backed up because we are going to format it...
Open the HP Format Tool
Start/Programs/Hewlett-Packard Company/HP USB Disk Storage Format Tool
It should automatically select your USB Drive.
Select FAT or FAT32 Under File System.
Select Create a DOS startup disk
Select using DOS system files located at and point to the folder containing the boot disk files.
Then click Start
Or you can download Win to flash ,follow the bellow link for details,
For Windows xp
http://www.intowindows.com/bootable-usb/
Or
http://www.makeuseof.com/tag/how-to-create-a-bootable-usb-drive-from-your-windows-cd/
For vista
http://downloadsquad.switched.com/2009/08/27/make-a-bootable-usb-installer-for-windows-xp-vista-7-with-wint/
Hope this helps.
Let me know if you need more information
Thanks.
Apr 26, 2011 | HP Compaq nc6320 Notebook
I brought a 2bd hand Zoostorm netbook with an 8 gig ssd card, how can I copy an operating system onto the card as the XP on it is faulty, and will not start. I have a USB 3.5 inch floppy, and a USB cd drive. Please help Many Thanks Colin Mason
You need to make a bootable usb install for windows (these directions are for vista but should be the same for xp)
This tutorial will help you in creating a bootable USB drive of Windows Vista which you can use to install Vista in any system. It might become very useful when you don't have access to DVD drive.
1. First format your USB drive in NTFS file system. You can do it by attaching your USB drive to your system and then format it from My Computer window.
2. Now open Command Prompt window from Start menu. Right-click on Command Prompt entry in start menu and select "Run as administrator" option.
3. Now type diskpart in Command Prompt window and press Enter. It'll launch DiskPart program:
list volume
It'll show a list of all drives in your system. Look for your USB drive entry. As in the below screenshot, the USB drive is "G" which you can determine from its "Type" entry.
Now you have to select the USB drive volume by providing select volume no. command. Since in our case volume no. of USB drive is "Volume 4", the command would be:
select volume 4
active
5. Now we need to create Boot sector on USB drive. We'll use "bootsect.exe" utility for this task. You can find this utility in Windows Vista setup disk. It'll be present in "Boot" directory.
bootsect /nt60 G:
Here G is drive letter of USB drive. Replace it with the correct drive letter if your system has some other letter for USB drive.
You can also see the directions here http://www.askvg.com/how-to-create-bootable-usb-drive-to-install-windows-vista/
Dec 26, 2009 | Computers & Internet
446 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
