Tip & How-To about Computers & Internet
Adjust the level 2 cache setting
  1. Here'show:
    1. Launch the Registry Editor (Regedit.exe).
    2. Go to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory Management.
    3. Double-click SecondLevelDataCache DWORD value.
    4. Using the options below, change the value in the Value Data text box to a number that matches the size of your Level 2 cache. Then click OK. Level 2 cache Value Data setting
      256 KB 0
      512 KB 200
      1024 KB 400
    5. Click OK and close the Registry Editor.
    You may need to restart the system or log out of Windows XP for the change to take effect.
Computers & Internet Logo
wat does regedit means
regedit is an an inbuilt Microsoft Registry Editor. To start the regedit.exe go to Start>>>Run>>> type regedit and click OK. The Microsoft Registry Editor (regedit.exe) enables you to view, search for, and change settings in your system registry, which contains information about how your computer runs. Although you can use Registry Editor to inspect and modify the registry, doing so is not recommended, because making any incorrect changes can damage your operating system. Please go to http://en.wikipedia.org/wiki/Windows_Registry for more details.
Mar 22, 2012 | Acer Computers & Internet
how i can reuse the norton 360 v 4.3.0.5 Its trial period is expired. Plz send me product key or trial reseter. special thanks
Please remove the existing version of Norton program from the control panel, then go ahead and delete all Symantec and Norton files from the computer's C or D drive.
After that, open your registry and first take a back up just in case anything get deleted by mistake.
Then delete all Norton and Symantec files from HK CURRENT USER, HKEY LOCAL MACHINE, HKEY USERS, HKEY CURRENT CONFIG.
You can click on the SOFTWARE folder in each class to find the Norton files if any.
To open your registry editor, type regedit in RUN command (windows key+R)
After that you can again install a trial version of Norton for 30 days.
Feb 05, 2011 | Symantec Norton 360 Full Version for PC...
Deleted Sonic DLA because of crashes and now computer won't recognize unformatted disc in drive
Go to the registry and delete the lower and "upperfilters"for the CD/DVD drive option. you can access it by going to this option. REGEDIT >> HKEY Local Machine >> System >> CurrentControlSet >> Control >> Class >> Select for the option which is the first {4D36.....}. After deleting the upper/lowerfilters, close the Registry Editor and restart the laptop. Then there try inserting a blank disc or any disc. Thank you.
Oct 07, 2009 | Dell Inspiron 6000 Notebook
system's registry
The system's registry editor can be found on Windows XP by clicking on the start menu and selecting 'Run' and type 'regedit' and press on enter. The system registry editor should launch. On windows Vista, you just click on the Pearl (Start) and on the Start Search box, type 'regedit' and then enter.
For the CD/DVD drive problems that requires registry editing information, you can find the instructions on this link http://support.microsoft.com/kb/929461
Sep 09, 2008 | Pioneer DVR-107D DVD±RW Burner
163 people viewed this tip
David Payne
David Payne
