Tip & How-To about Microsoft Xbox 360 Wireless Controller
Optional way to turn on controller 4 an xbox 360
Its very simple to do really. incase you moded you controler and a cord always gets in the way when you need to push the center button just push te start button and then push/hold the start button again til the controler turnes on thus turning ont the consel to
Microsoft Xbox 360 Wireless Controller Logo
I can't get my remotes to sync with the console.
Connecting a controller to the Xbox 360 is one of those things that should be simple but always ends up confusing and difficult.
Wired is simple; just plug in the controller into a USB slot on the console. It should connect automatically.
For a wireless controller you do the following:
1. Turn on the Xbox 360.
2. Press center Xbox button on 360 controller.
3. Press the small "sync" button on the console.
4. Press the small "sync" button on the controller quickly after step 3.
Of course I never remember the order, so randomly mashing the Xbox button and sync buttons eventually works too. Here's a link to how to sync, but with pictures!
If you're using the Xbox 360 Universal Media remote, I believe it uses an IR (infrared) connection so there is no syncing involved. To use it you just need to point it at the Xbox 360 console (specifically, it's IR receiver). Just make sure the batteries in the remote aren't dead and that the remote is in 360 mode (as opposed to TV mode; just press the "TV" button to toggle modes).
Mar 22, 2011 | Microsoft Xbox 360 Console
how to reset error e4
The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing this reset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′.
Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset ink level notification:
  1. Push “resume” for 5 seconds for canon IPXXXX. For canon MPXXX you must enter to service mode.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Enter to service mode for canon MPXXX
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
Apr 15, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
how to set the time on kdc-mp3035
1. Select Clock Adjustment mode by doing this:
Push the control knob towards [FM] or [AM] (unit must be in the stand-by mode, ie: turned off)
2. select the CLK ADJ display
3. To enter clock adjustment mode, press the control knob for at least one second. The clock display will blink.
4. To adjust the hours, push te control knob towards FM or AM.
5. To adjust the minutes, push the control knob towards |<< or >>|.
6. To exit the clock adjustment mode, press the MENU button.
This information was taken from the instruction manual that I was able to find online. Shoot me an e-mail and I'll forward it off to you. (page 20)
Mar 09, 2008 | Kenwood KDC-MP3035 CD Player
Tissot T-Touch
Hello, if u read the user's manual, there is an option to resync the hands. Goto the units mode ( Press the middle button, and then twice in the center of the screen, so that the digital display shows either 24h Cm or 12h... u get it ) Once in that press and hold the middle button for 5 seconds, until the display shows SYNCHRO. Then use te top button to adjust the minute hand and te bottom button to adjust the hour hand, and bring them both, one on top of the other, over the 12 o'clock position. Once this is set, press the middle button again. This should to the trick.
Oct 24, 2007 | Tissot T33.1.588.51 T-Touch Dial
627 people viewed this tip
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
