Tip & How-To about Computers & Internet
How to remove a malware out
Anti-virus remover!Scan All Drives on the system PC, if messages keeps, "Quarantine"(checkmate the Message) working when he detect, Turn off System Recovery (My Computer>View Information>System Restore) Unchecked "Turn off System Restore on all Drives" > Restart the PC, in Start Press the key "F8" > "Safe Mode" wait..."Administrator">Message Appears: Click "Yes" then wait start...go to the anti-virus program and remover all the malicious from the "Quarantine" , when is over go back the way to turn, inside PC to the system restore and turn in on.
Computers & Internet Logo
What is fix me stick used for
Pros
Bootable, USB-based antivirus uses scanning engines from Sophos, Kaspersky, and GFI/VIPRE. Extremely easy to use. Full undo in case of problems (means you can "undo" whatever it's done if you find a problem with its action"). Remote-control tech support available if needed (you will pay for this support, so be careful).
  • Cons Can't disinfect virus-infected files, can only quarantine them. Quarantine of system files rendered two test systems unbootable, requiring full undo. Can't handle malware traces in Registry. Alleged removal failed to prevent several detected rootkits from running (when you use multiple services to try to completely disinfect a computer, removal of viruses is NOT an option - only quarantine - which means the infected file is still on your computer).
  • Bottom Line
    When a nasty malware infestation leaves Windows non-bootable or prevents antivirus installation, the USB-based bootable FixMeStick offers an easy-to-use solution. In testing it didn't clean up everything, but then, it's not intended as a standalone solution. This product's aim is to get your PC into a state where your desktop antivirus can finish the cleanup.
  • I pasted the above from a Google search, and will add to it here: If you want to really clean up your computer, and cannot install a good program to do the job, this stick may help you get back into your system and get things under control. However, several things are important from here on. 1 - always do a back up of all critical file, and consider using cloud back up (such as drop box). 2 - use real QUALITY Anti-Virus software. I helped test the top 100 about 6 years ago, and Vipre Internet Security was #1 in every category - anti-virus - anti-malware - and limited use of system resources (about 11% - compared to 34% for Norton or McAfee). The best security on any computer is the person at the keyboard. NEVER open unknown emails, never visit questionable site and such. Manually scan your computer at least once a month (or more) to keep it clean, keep the Recycle Bin empty, and use Ccleaner to keep the registry minimal. Good luck and God bless...
    Feb 18, 2015 | Computers & Internet
    how can i removed the viruses on my pc?
    Two of the more easy, reliable and free anti-virus software you can download are:
    AVAST
    ESET
    Either one of them will always guard every aspect of your computer and online activity. You MUST be online for any anti-virus software to update it's engine and virus database regularly. Also, MALWAREBYTES is a free anti-malware that guards against other kinds of dangerous computer bugs, and works very well.
    Once you've updated whatever anti-virus software you have, then run a complete scan of all your drives and put all viruses into quarantine or repair the files, or remove the nasties completely.
    Sep 19, 2012 | Computers & Internet
    how do i restore my compaq presario v2000 to factory condition without recovery CDs, F10 and F11 not working and NO System Recovery option in the start menu
    Your computer is infected with viruses. Solution: install and update anti-virus. You can use anti-virus free (Avira or AVG). Perform a virus scan process, with the option, if a virus is detected, the primary action "Repair" and secondary action "Quarantine".
    hopefully help
    Sep 23, 2011 | HP Compaq Presario V2000 Notebook
    operanting sistem in quarenten
    Any antivirus; unless it finds virus, never moves a file to quarantine. If it moved, then probably your OS is occupied entirely by virus.
    Which antivirus are you using? Are you able to login into your system ? If yes, open the quarantine folder and replace all items. It is best if you do it in safe mode. Then scan for that trojan horse again. But before that, back up your important data and then scan. I recommend you remove all the virus after backing up of data and format your system once (all drives) and do a fresh install of OS.
    If you are unable to open quarantine, try system restore to restore to a point earlier before that scan. It is in All Programs>Accessories>System Tools.
    Jan 16, 2009 | Microsoft Windows XP Professional
    I have a virus and stmanteec antivirus notification keeps popping up on my screen: What can I do??? Help Scan type: Auto-Protect Scan Event: Threat Found! Threat: Trojan.Zlob File: C:\WINDOWS\system32\813686\813686.dll Location: C:\WINDOWS\system32\813686 Computer: LAURA User: Administrator Action taken: Clean failed : Quarantine failed : Access denied Date found: 17 November 2008 14:43:10
    If you have a virus you can not delete or if your system will not boot up correctly and you suspect a virus is the problem, a recommended solution is to start your computer in safe mode and run a virus scan. By running your computer in safe mode, non-essential processes do not start and non-core components are disabled. In other words, only the minimum necessary programs will load. Tough to remove viruses, spyware and other malware usually have no chance to run and disrupt your system and can more easily be removed.
    **To run a virus scan in safe mode, you must have active anti virus software installed on your computer.
    To run a virus scan in safe mode, follow these steps:
    1. If your computer is on, shut it down
    2. Power on your computer
    3. Immediately after you power on your computer, repeatedly press the [F8] key (about once per second)
    4. In the Windows Advanced Options Menu screen, use the arrows to select Safe Mode and presss [Enter]
    5. Select your current operating system and press [Enter]
    6. Select the user you would like to login under (if applicable)
    7. When your system finishes booting, click the Start button on your task bar
    8. Move your cursor over All Programs and navigate to your anti virus program
    9. Click on your antiv virus program to run it and follow the anti virus program’s normal steps to run a virus scan
    10. After the virus scan is complete, Delete all detected viruses
    11. Close out of your anti virus software
    12. Restart your computer (it should start in normal mode)
    Nov 17, 2008 | Computers & Internet
    181 people viewed this tip
    David Payne
    David Payne
