Tip & How-To about Dishwashers
PANASONIC WITH FUZZY SPOTS
FIXYA TIP PANASONIC
I hope this not AN old TIP, but I still see it asked and not answered properly by some.
TIP:
PANASONIC:
MODELS: PT-44LCX65, PT-52LCX15, PT-52LCX65, PT-52LCX35,
PT-61LCX65, PT-61LCX35.
SYMPTOMS:
1. FUZZY SPOTS
2. FUZZY SPOTS WITH STAINS
3. FUZZY SPOTS & UPSIDE DOWN
4.. FUZZY SPOTS WITH LINES
5. LOOK LIKE BAD LIGHT ENGINE.
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM CORRECTION TOOL; (LSUQ0100).
It is an easy repair (about 7 minutes), it takes longer to take the back off to perform this procedure.
Can't be purchased unless you have an account, customers can not purchase.
Thanks, Big IRISH.
Dishwashers Logo
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm noticing a light blue color in the bottom left part of the screen. How can I fix this? My TV is 5 years old...is it still under warranty? It's a shame that a $2,000+ TV is starting to degrade.
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
panasonic tv model pt-44lcx65
Howdy,
The problem is with the EEPROM in the TV that needs to be reprogrammed. But you need to have the proper Correction Tool (LSUQ0100).
I don't think it's available to the public. Call a Service Company, but make sure they have the “Correction Tool”.
Thanks for using FIXYA, big IRISH.
May 27, 2009 | Panasonic PT-45LC12 45" Rear Projection...
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
computer vga to tv
I'm guessing you've resolved this by now, but, if this is a laptop computer, it is actually a function of the computer that you are looking for and not the TV. Typically there is a key function assigned to directing the display to the laptop only, the tv only, or both simultaneously. On my current laptop it is fn+F8. On my old Dell I think it was ctrl+F8
Hope this helps, sorry so late.
Aug 06, 2008 | Panasonic PT-44LCX65 Television
261 people viewed this tip
Top Dishwashers Experts
