Tip & How-To about Computers & Internet
Get space back on your hard drives! / Reclaim missing space
If your drive is nearly full and you can't work out where the space has gone, heres 2 things you can do about it.
1. Turn off System Restore
System Restore is a nice feature built into Windows that allows you to "go back in time" in case something bad happens. However, it takes up a LOT of disk space. You can turn it off (or at least turn down the space it takes up) by doing the following:
--On Windows XP--
Right click "My Computer"
Properties
System Restore tab
Tick "Turn off System Restore" and press Apply to turn it off and reclaim your disk space
OR Drag the slider all the way to the left to REDUCE the amount of space it takes up (and the number of "restore points" it creates).
--On Windows Vista--
Properties
on the left hand side click on "System Protection"
Wait for it to load, then uncheck all the drives you want to turn System Restore off on those drives.
Hit Apply or Ok.
Done! You just got some space back.
Note that System Restore isn't a critical feature to recovering from a computer problem, though it may help / save some time. If you wish to keep it on, you may wish to consider "turning it down" as described above to reclaim drive space.
2. TreeSizeFree
TreeSizeFree is a completely free software that lets you find out WHICH folders are taking up all the space on your hard drives. Its very simple to use and very small (theres even a portable version which requires no installation), just press Scan->Select the hard drives you want to check, wait a few minutes, and you'll know exactly how your hard drive space is distributed.
TreeSizeFree can be downloaded at:
http://www.jam-software.com/freeware/index.shtml
Computers & Internet Logo
Emachine D3107 slow.
1. Check for hard disk space nearly full.
2. Check startup applications. Remove via Control Panel or "msconfig".
3. If running low on RAM, add more physical memory.
4. Perform a virus check and disk defrag.
Jan 25, 2014 | Computers & Internet
Hello masters of FixYa. Today, I connected an
Not sure why this happened but I suggest you download and run c cleaner, it's safe and effective and assuming that your free space was overwritten with temp files you should be able to get it back.
On the c cleaner interface you will see a tab called 'System Restore' You can use this to clear all but the most recent restore point which should help free up space also.
I hope this helps.
Here's a link to a download page for ccleaner...... http://www.filehippo.com/download_ccleaner
Mar 06, 2011 | Dell Computers & Internet
acer 5315 HD C is full HD D empty
Very likely the answer is yes, IF: 1) there is enough space and 2) that D drive is not being used for something else. Check on what is on the D drive. It's usually reserved by the manufacturer and contains OS restore files (used for restoring your system after a crash). Don't delete these, but if there is enough free space, just create a new folder and put your files in there.
Jan 31, 2010 | Acer Aspire 5315 Notebook
recovery disk full and windows explorer keeps feezing
right-click on "My Computer" then select properties, then System restore.
You now have two choices, expand the % disk space to use for the system restore, or Turn off System Restore, which will wipe out all past restore points.
Do the first one, see if everything goes back to normal. if not, then run disk cleaner foundat: start, programs. accessories, systems tools. This should mkae your Operating system speed up a bit by cleaning out temp files and other clutter. Then defrag, also found in the same folder as Disk cleaner. Next, do a search of your entire hard drive for all files ending in .tmp. delete them all. Those steps combined, should speed things up considerably. Only when everything is working fine again should you turn of system restore and then turn it back on again to get everything cleaned out. This last should be a last resort only, when you are running out of Hard drive space.
Jul 09, 2008 | Computers & Internet
Loosing Hard Drive space
Do you empty your trash??? Do you have a virus?
Jul 08, 2008 | IBM ThinkPad A31 Notebook
192 people viewed this tip
David Payne
David Payne
