Tip & How-To about Video Game Consoles & Games
Need For Speed Shift Keyboard tips
For anyone who uses keyboard in playing NFS Shift try one these settings.
Steering Dead Zone-15%
Accel Dead Zone-10%
Brake Dead Zone-10%
Steering sensitivity-5%
Acell Sensitivity -5%
Brake sensitivity-5%
Speed steering Sensitivity 100%
Steering Dead Zone: 50%
Accelerator Dead Zone: 25%
Brake Dead Zone: 5%
Clutch Dead Zone: 10%
Steering Sensitivity: 100%
Acceleration Sensitivity: 40%
Braking Sensitivity: 50%
Clutch Sensitivity: 40%
Speed Steering Sensitivity: 0%
Inverse Shifting: Off
Camera Y Axis: Normal
AI Difficulty: Medium
Handling Model: Normal
Steering Assist: Low
Braking Assist: Off
Anti-Lcok Brakes: On
Traction Control: Low
Stability Control: On
Damage Effects: Full
Gears: Automatic or Manual
At least anyone can now enjoy the game without having the hassle of wheels and other devices cluttering up their desk.
These settings work well in the new 1.02 Patch hope these helps.
Video Game Consoles & Games Logo
How do I take apart Madcatz mc2 pedal set
I started having trouble with my brakes and throttle either not operating or operating sporadically (MC2 pedal set). I tried slightly jiggling the cord near the connection on the steering wheel base and found I could get the pedal set operating again. To keep the pedal set operating while I play (drive), I drape the pedal set cord over the steering wheel set gear shift. Amazingly, that one difference keeps the pedal set operating consistently. By the way, I had ordered another pedal set in the box on E-Bay when I found this draping technique worked. The E-Bay set is still in the box in my closet as a back-up. Don't need it ... yet. This is what I have been doing since the issue occurred about two years ago. Hope this resolves your issues.
Sep 21, 2014 | Mad Catz Madcatz Nascar Gaming Steering...
WERE IS THE FUSABLE LINK IN 1993 COROLLA?
I found this useful diagram at troubleshoot vehicle.com. It answers your question. Fuse box is located below steering column.
Driver Side Fuse Panel
(1993-1996 Toyota Corolla) December 21, 2013 Updated: December 21, 2013 Written by: Abraham Torres-Arredondo driver-side-fuse-box.gifIn the table below you'll find the fuse location and description of the fuses of the driver side under-dash fuse box on 1.6L and 1.8L 1993-1996 Toyota Corolla.
The fuse box is located on the driver side of the dash, below the steering column.
1993-1996 Toyota Corolla Driver Side Fuse Box Fuse Fuse Name Amps 1 Cigarette Lighter, Digital Clock, A/C System, A/T Shift Lock, Alarm, SRS Airbags 20 2 Tail, Parking & License Lights, Instrument Panel and Daytime Running Lights 15 3 Fuel Injection, Cooling Fans, Battery Discharge Light 10 4 Cruise Control System, Daytime Running Lights 10 5 Fuel Injection System 7.5 6 Stop Lights, Cruise Control, Shift Lock System, Anti-Lock Brake (ABS) System 15 7 Turn Signals, Emergency Flashers 10 8 Starting System, Anti-Lock Brake (ABS) System, Shift Lock System 15 9 Gauges, Reminder Lights, Back-up Lights, A/C System, Daytime Running Lights 10 10 Front and Rear Wiper/Washer System 20 driver-side-fuse-box.gif
Jul 06, 2014 | 1993 Toyota Corolla
location of fuse to control side mirrors on 2009 97x
Fuse panel in end of fascia
No. Amp. Function
1 15 Steering wheel lock
2 5 Steering column unit; ignition switch
3 10 Hands-free; cabin CD changer; SID
4 10 Main instrument unit; manual climate control;
automatic climate control (ACC)
5 7.5 Control module in front doors; Park Brake Shift Lock
(automatic transmission)
6 7.5 Brake light switch
7 20 Fascia fuse panel; fuel filler door
8 30 Control module in passenger front door
9 10 Fascia fuse panel
10 30 Trailer socket; electrical socket in storage compartment
between seats
11 15 Data link connection (diagnostics)
12 15 Interior lighting incl. glove compartment
13 30 Accessories
14 20 Radio, sound system I; control panel,
Infotainment System
15 30 Control module in driver's door
16 - -
17 - -
18 7.5 Manual climate control; fan
19 - -
20 7.5 Headlight levelling switch
21 7.5 Hands-free; brake light switch; manual climate
control; clutch pedal switch
22 30 Cigarette lighter
23 40 Cabin fan
24 7.5 Airbag control module
25 - -
26 5 Yaw sensor (cars with ESP)
27 - -
Trunk fuse panel, left-hand side
No. Amp. Function
1-5 MAXI -
6 30 Control module in left rear door
7 30 Control module in right rear door
8 20 Trailer
9 - -
10 30 Left-hand brake light; rear right turn signal; right tail
light; right reversing light; high-mounted brake light;
trailer lights
11 - -
12 - -
13 - -
14 - -
15 15 Seat heating, left seat
16 15 Seat heating, right seat
17 7.5 Autodimming rearview mirror; rain sensor; tire
pressure monitoring
18 15 Sunroof
19 7.5 Telematics (OnStar)
20 7.5 DVD player (navigation system)
21 7.5 Saab Parking Assistance (SPA); control module in
rear doors
22 30 Amplifier, sound system III
23 - -
24 10 Movement sensor; CD changer in trunk (accessory)
25 30 Electrically adjustable driver's seat with memory
26 30 Right-hand stop light; rear left turn signal; left tail
light; rear fog light; left reversing light; license plate
lighting; trunk lighting; trailer lights
27 - -
28 - -
29 - -
Fuse panel in front of battery
No. Amp. Function
1 60
MAXI
Secondary air injection pump (certain models)
2 20 Fuel pump; preheated oxygen sensors (lambda
probe)
3 10 A/C compressor
4 30 Main relay
Relays
1 Secondary air injection pump
2 A/C-compressor
3 Preheated oxygen sensors (lambda probe)
4 Main relay, engine (ECM/EVAP/injectors)
Sep 13, 2012 | 2006 Saab 9-7X
NFSU2, NFS carbon and NFS most wanted - Keyboard not functioning correctly
LOL, probably a Windows 7 conflict if you just upgraded. It has tones of problems just like it's predecessor Windows Vista.
Apr 24, 2012 | Computers & Internet
3,772 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
