Tip & How-To about Computers & Internet
Is there a program out there that will convert my old cassette tapes or vinyl records to CD?
The short answer is yes. There is a program out there that will record cassette tapes or vinyl records to CD. Today, I will show you how. If you have the right software and the right cords, getting your cassettes and Vinyl onto your computer, then onto CDs, is a pretty easy task. Just follow the steps below and you will be on your way to bringing your audio into the 21st century! What you need: To make the conversion, you will need a (free) audio recording program, a tape or record player and a cord to connect the device to your computer. Here's a breakdown:
1. Audacity. This is the program that will record your audio to your computer.
2. LAME-encoder. This is a file that will convert your audio to MP3.
3. A record player or cassette player. Hopefully you already have one of these.
4. A cord to connect the player to your computer.
The first step is to install Audacity and LAME,
Now that we have the software installed, we can look at connecting your tape player, or record player, to your computer.
Your player will have one of two types of outputs. You will either have a standard 3.5mm headphone jack, or RCA audio output jacks.
If your device has RCA outputs (left image)to connect to your computer.
If your device has a 3.5mm jack (right image) to connect to your computer.
The other end of the cable will connect to the line in jack on your computer
Now that we have the software installed and the cassette/record player connected to the computer, let's record something!
Put a cassette or LP into your player. Get the player to the place where you want to start recording and pause or stop the player.
Now, let's stop messing with all this hardware and get the computer set up. First, go to your control panel and open your audio settings.
In XP, go to the audio tab and click "volume" under sound recording. Place a check next to "line in". If you don't see a "line in" option go to options and click advanced. Place a check next to "line in" there.
In Vista/7 go to the recording tab. find your line in, select it then choose "set default". Click on "properties", go to the levels tab and turn up the level to 80 or 100. (This varies depending on what you are recording so you may need to adjust this to get it right).
As you can see, Audacity is pretty much a more advanced sound recorder. To begin recording, press the play button on your record/cassette player then click the red "record" circle on audacity. You are now recording to your computer! When you are done, click stop on audacity and press stop on your player.
After recording, you can now export your audio as an MP3. Go to the file menu and click "Export as MP3". You can now choose the name of the file and save to wherever you want. You are done recording!
Computers & Internet Logo
vinyl recording turntable
The Denon will act just like a standard tape recorder. It should have an audio in, for recording. If that socket is connected to the audio out of a tape socket on your receiver, the Denon will pick up the signals that are sent to your receiver from whatever source. All you have to do is follow the instructions for recording on the Denon then. If you have lost the user manual for it, it's free on-line.
Jun 22, 2017 | Denon CDR-W1500 2-Disc CD Recorder
I have the Victoria tunewritter GDI-TW4CD. Sadly when I push play after record, wheile recording vinyl to CD I get backwards 344 error? help please
I don't have an answer to your question but at least your cassette player door closes once you insert a cassette mine does not
Nov 02, 2013 | Brookstone Victoria Tunewriter III USB...
I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling arrangement through the amplifier. I have not been able to figure out the right cable connections from my turntable to the RCD-W500C. Is an amplifier necessary, or optional?
Your new cd player/recorder is a "component piece" as is your turntable,cassette player, reel to reel or CD player. Connect it as you would any other component piece of stereo equipment. Set up your recorder to "record" in real time(not high speed or synch record). Your tape recorder records anything that is playing through your reciever to your speakers. So, treat your "CD" recorder as you would a "CASSETTE TAPE" recorder. Play your vinyl record on your turntable and record to CD on your CD recorder ! Pay special attention to the dubbing speed, you will not use "synch or high speed !! Good Luck
Feb 26, 2011 | Audio Players & Recorders
how to record a cassette from cd on a sony xplod boombox cfd-g505
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDG505
Mar 17, 2010 | Sony CFDG505BLACK Xplod CD Radio Cassette...
226 people viewed this tip
David Payne
David Payne
