Tip & How-To about Computers & Internet
ALTERNATIVE TO THE EXPENSIVE CPU FAN
IF YOU ENCOUNTER TO THE PC THAT YOUR CPU FAN IS NOT WORKING OR IT IS ALREADY DEFECTIVE... INSTEAD YOU BUY A EXPENSIVE FAN FOR PROCESSOR, YOU CAN USE AN ALTERNATIVE USING CASE FAN>>> IT'S MORE EFFECTIVE TO BRING AIR TO YOUR PROCESSOR TO AVOID OVERHEATING AND IT'S ALSO CHEAP TO BUY TO THE MARKET..... ALL HAVE TO DO IS ATTACH THE FAN TO THE HEAT SINK USING ANY ADHESIVE MATERIAL OR TIE IT TO THE HEAT SINK. IT CAN PROVIDE MORE AIR THAN THE ORIGINAL ONE. TRY IT! BECAUSE IN MY OWN COMPUTER, IT IS ALREADY TESTED.....
Computers & Internet Logo
my vostro 200 encountered cpu fan failure but i use it then it shots down and never runs it again what should i do???
Hi, its not a good practice to use a pc without a CPU fan. most cases the fans pc shuts down to prevent damage to the CPU. i will advance you take it to a technician to have the fan replaced. then it will work if the CPU has not already been damaged by you trying to use it without the fan. but i am sure that is not the case. get the fan changed and you pc will work again
Oct 16, 2012 | Dell Vostro 200 Desktop Computer
I have desktop computer with celeron processor CPU 240 GHz and 512 MB ram with 40 GB HArd disk.. I see my hard disk encountered some problem and planning to by new hard disk ..which is best for me and the capacity? and also can i add another 512 MB ram or should i change the processor with the motherboard??? please assist me in this
Hi ,
I assume you are under Windows XP but this will also work under Windows 7 32 bit .
You can insert a 100GB HDD without any problem . A higher capacity is risky with your type of machine and could lead to a fatal read error , meaning you couldn't boot your unit anymore .
Under a 32 bit XP system , 2GB ram is the max.
I don't recommend changing the processor with the motherboard , you could encounter conflictual issues with the rest of the unit .
Buy yourself a new pc equiped with a I5 or better with a I7 processor running under W 7 64-bit is the solution but they still are expensive .
Best regards .
Jan 30, 2011 | eMachines Desktop / Intel Celeron...
My fan runs extremely loud on and off
It is set up to run if CPU gets warm/hot. Quiet normal.
If it didn't you would son know. One Cooked CPU with Chips. Expensive tak Away.
Some fans are noisey. You could go to the expense and have a replacement???
Nov 16, 2009 | HP Pavilion dv2915nr Notebook
new motherboard and cpu: no post
I have encountered that kind of problem before in the AMD processor. When your turn on the switch the fan is spins and then suddenly stop. The processor is shorted or there is defective parts you need to return it to the supplier. But can you check first if the motherboard and the processor is match . Maybe the motherboard cannot carry the speed of the processor it's better to ask to the supplier or ask them to test both the processor and motherboard .
Apr 17, 2008 | MSI 945GCM5 Motherboard
my mother board
hi icebox143ph,
just insert ur proceesor in ur motherboard if processor fan is moving than the motherboard has minor defect i.e display problem if processor fan is not moving than the motherboard ic has burn
Mar 06, 2008 | Foxconn WinFast K7S741MG Motherboard for...
285 people viewed this tip
David Payne
David Payne
