Tip & How-To about Heating & Cooling
Air Conditioner SEER Seasonal Energy Efficiency Ratio
Energy consumption for home air conditioning accounts for almost 5% of all the electricity produced in the USA. Energy Policy Act mandates minimum energy efficiency standards for commercial buildings, using research and standards developed by the American Society of Heating, Refrigerating, and Air Conditioning Engineers. Energy Star qualified central air conditioners have a higher seasonal efficiency rating (SEER) than standard models, which makes them about 14% more efficient than standard models. Energy efficiency specialists with certified training on retrofits and energy savings on both residential and light commercial units may enable you to save up to 50 percent on your air conditioning bills with the use of a high efficiency energy system. Substantial energy savings can be obtained from more efficient systems.
SEER (Seasonal Energy Efficiency Ratio) is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics. SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations.
The SEER rating is the Btu of cooling output during a typical cooling-season divided by the total electric energy input in watt-hours during the same period. SEER is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics. SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations. The higher the SEER number, the greater the efficiency of your unit. Therefore you will realize greater energy savings. The higher efficiency your product, the lower your long-term energy costs will be. Both central AC and air source heat pumps are rated according to seasonal energy efficiency ratio (SEER).
Before you consider upgrading your cooling equipment, the cheapest way to save money and energy from cooling is to reduce the need for mechanical air conditioning in the first place. Ask your contractor about a variable speed air handler, which will improve comfort and efficiency and allow continuous air filtering at minimum energy cost. Also, because ducts are often responsible for a lot of wasted energy, make sure you hire a contractor who knows about high-efficiency installations. If your central air conditioning unit is more than 12 years old, replacing it with an Energy Star qualified model could cut your cooling costs by 30 percent.
Heating & Cooling Logo
10 advantages and 10 disadvantages of electricity
Hmmm
Advantages
storable
can be transmitted over distance
convertable to other forms of energy eg force
can be produced cleanly
can be produced renewably
versatile
consumption can be waste free
Disadvantages
can be dangerous
requires much physical infrastructure
cheaper methods of production are dirty
much consumption of it is wasteful
Sorry I did not get to 20
Oct 11, 2013 | Exercise & Fitness
I have a RUDD UPNE-042JAZ. How many tons is that?
That is a 3.5 ton heat pump at 13 SEER.
A S.E.E.R. (Seasonal Energy Efficiency Rating) is the rating and performance standards that have been developed by the U.S. government and equipment manufacturer's to produce an energy consumption rating that is easy to understand by consumers. It has a universal formula and conditioning that can be applied to all units and compensates for varying weather conditions.
Basically, the lower the S.E.E.R. rating, the more energy (electricity) is required to produce the desired effect.
Jun 13, 2011 | Heating & Cooling
how do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
1,065 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
