Tip & How-To about Heating & Cooling
What Size Air Conditioner Do You Need?
Air conditioning is not an exact science. There are many variables that can affect the way an air conditioning system performs. Also there are many factors that can affect the size of the air conditioner that you need. What I want to get into next is the problems that can show up from an air conditioning system being either too big or too small.
You have three estimates for central air conditioning in your house? Each estimate quotes you a different size unit. What do you do? Buy the middle one because they are between the other two? You may be happy and maybe not. Let me explain how this works and what the results are of not getting it right.
If the air conditioning unit is undersized, this is actually the lesser of the two evils. If your system is too small the worst that can happen is not nearly as bad. An air conditioning system that is too small will just not quite keep up on a very hot day. This usually is not that noticeable because as long as there is a difference between the inside and the outside temperatures you will still be happy. If the house is 80 degrees on a 95 degree day, you still feel rather cool in the house. The other advantages to the under sized air conditioning system is that you still get very good dehumidification on a mild rainy day when you still want some cooling and everyday that you are running the air conditioner you are saving money. Yes, even if the air conditioner is running longer, you are still saving money because it is using less power. The efficiency of the slightly undersized system will be much higher than the oversized system.
If your central air conditioning system is too big for the space being cooled you are actually worse off than if it was too small. Yes too large of a system creates some major problems! If your system has too much capacity and cools your house off too quickly, you will not get he secondary effect of that an air conditioner is designed to give you. The second benefit of your system is to dehumidify the air. If your system can cool the air very rapidly before it has time to take the water out of the air, you will not have a comfortable house. This also goes for any other building. Have you ever entered a store and it felt like you just walked into a refrigerator? That is because the equipment is so large that it is cooling the air, but not removing the water out of the air. The effect is a very uncomfortable cool. This can happen in homes, but usually to a lesser degree. The discomfort may not be that pronounced, but it will not be as comfortable as it could be.
So, as you can see size really does matter when it comes to air conditioning. The oversized system will give you an uncomfortable cool and waste energy at the same time. Neither of these things are something that you want. The undersized system may allow the temperature to creep up a bit on a very hot day, but will save energy and give great comfort most of the time. The ideal sizing is for the unit to be running constantly on the hottest day of the year and barely be able to keep up. When you are shopping for central air conditioning make sure that you tell the salesperson what you want and insist on seeing their heat loss/gain calculations for your building. No one can guess at what you need and do it correctly. Making sure you have the right central air conditioning for your house or building will make you comfortable and happy for many years to come!
Heating & Cooling Logo
Where exactly is the switch for the air suspension compressor on a 2006 Buick Lucerne CXL?
The automatic level control (ALC) system maintains a desired rear suspension position under all types of towing, hauling, and loading conditions.
The system uses the electronic suspension control module (ESCM), ALC relay, ALC compressor assembly, air dryer, air lines, LR and RR shock absorbers with integral air chambers, LR and RR suspension position sensors, exhaust valve, driver information center (DIC), and the serial data circuit to perform the system functions.
What switch ? there are sensors at the wheels that control the system .
The system uses the automatic level control module (ALCM) with integral suspension position sensor, ALC relay, ALC compressor assembly, air dryer, air lines, LR and RR shock absorbers with integral air chambers, exhaust valve, driver information center (DIC), and the serial data circuit to perform the system functions.
The
Jul 10, 2016 | Buick Cars & Trucks
computer analysis showed these codes... P0330 P1133 P1135 P1346 P1349 P1351 P1354. can anyone tell me what each of these mean?
P0330 Knock Sensor 2 Circuit (Bank 2)
P1133 Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1, Sensor 1)
P1135 Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
P1346 VVT Sensor Range/Performance Problem (Bank 1)
P1349 VVT System Malfunction (Bank 1)
P1351 Variable Valve Timing / CMP Sensor Range / Performance
P1354 Variable Valve Timing System Fault
NOTE:Variable Valve Timing (VVT) sensor is also known as camshaft position sensor.
The Variable Valve Timing (VVT) system controls intake valve timing in response to driving conditions.
Possible causes are:
  1. Incorrect valve timing P1346, P1349, P1351 & P1354
  2. Faulty oil control valve P1346, P1349, P1351 & P1354
  3. Faulty VVT controller assembly P1346, P1349, P1351 & P1354
  4. Faulty ECM All Codes
  5. Jumped timing belt All Codes
  6. Faulty Camshaft Position Sensor P1346, P1349, P1351 & P1354
  7. Faulty O2 Sensor (Bank 1, Sensor 1) P1133 & P1135
Apr 22, 2011 | 1999 Lexus ES 300
I have an 1992 grand marquis mercury the air condition is blowing but its not blowing as cold as it should. And it is also filled with freon.
compressors do get old & dryer/accumulators do get less efficient. if you have a poor cooling fan or cooling system those also can affect A/C performance, ovefull refridgerant system can also affect the performance. I would have a reputable shop inspect system performance & make sure you have the CORRECT amount & type of freon in the vehicle. If repairs are required make sure you upgrade to R134A . It's much less expensive & up to date.
Oct 15, 2009 | 1992 Mercury Grand Marquis
I have a 2001 gmc sonoma with obd error codes p0410 p0300 p0100
P0410 Secondary Air System PerformancePossible Causes Setting Conditions AIR solenoid Ignition circuit is open (check the U/H IGN fuse) AIR pump has failed (inspect air pump for water) AIR system check valves and/or pipes are damaged or leaking AIR system hoses or lines are damaged, pinched or kinked Base engine problem (e.g., excessive exhaust back pressure) PCM has failed P0300 Multiple Cylinder Misfire DetectedPossible Causes Setting Conditions Base engine mechanical fault that affects one or more cylinders EVAP system problem or the EVAP canister is fuel saturated EGR valve is stuck open or PCV system has a vacuum leak Fuel delivery component fault that affects two or more cylinders Ignition system fault (a coil) that affects more than one cylinder
Jun 08, 2009 | 2001 GMC Sonoma Extended Cab
3,174 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
