Tip & How-To about Audio Players & Recorders
Receiver say's "Protect" or turns on then off
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
tunr on the home stereo system for a minute and then the protect mode comes on and turns off the system
Sep 27, 2010 | Audio Players & Recorders
protect mode comes up
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
Jun 11, 2010 | Sony STR-DG520 Receiver
When turned on, the lcd flashes "protect" and nothing happens
Jan 09, 2010 | Sony STR-DE575 Receiver
sony reciver,home theater not working, flashes PROTECT all the time
Dec 29, 2009 | Sony STR-DE475 Receiver
Protect signal comes on and receiver cuts offafter about 4 minutes of use
Dec 23, 2009 | Harman Kardon HK 3380 Receiver
1,155 people viewed this tip
 Grubhead
Grubhead
