Tip & How-To about Office Equipment & Supplies
Printers and scanners and copiers (OH MY!)
How do I fix the error on my printer scanner copier fax that says "yada yada yada you cant print anymore"?
99% of the time, you cant. You arent supposed to. If you are a corporation that uses laser printers and you have a contract with a company, such as epson or hp or xerox or brother or whoever makes office copiers, then you can get them serviced. But if you are joe schmoe or a mom and pop shop, then you are just out of luck. Most times a printer issue is caused by a physical fault: something broke, something stuck, something is dirty, etc. If you have followed the procedures listed by the mfr for cleaning and maintaining the device, but it still fails, then it is likely not able to be repaired without great cost, and after paying that cost, you could have likely got a new printer.
For example, the Dell A960 printer scanner copier fax all in one device is about $30 bucks online. It does everything most people need. If it ever broke, youd spend 30 bucks an hour for the tech, plus the cost of parts, and would likely run into another issue a few months later.
Bottom line: unless you are a corporation, then dont try to fix the printer. once it dies, replace it. To make your life easier, replace it with the same model. For example, if your A960 dies, toss it out, buy another A960, hook it up, and have the new cables as spares. If that model tends to fail every few months, then get a different brand/model.
How do I cancel the transmission result report from printing
touch utility/counter button
administrator settings
enter password 1234567812345678
touch system
touch fax
touch report settings
then change it to print error only
Jan 24, 2013 | Konica Minolta Bizhub C224 Color Copier...
i cant send faxes over voip with the hp laserjet 3050 fax machine....really at a loss of what to do keep getting comm errors.....receiving faxes just fine
I found a blog on the Ooma site that said this can be fixed by prefixing your fax send number with 99. There were several comments from people who tired this fix and it worked for them!
Nov 23, 2009 | HP LaserJet 3050 All-In-One Printer
Lexmark X4270 Printer
I can receive fax but cant send fax
Mar 19, 2008 | Lexmark X4270 All-In-One InkJet Printer
error 41
print head defective. cant be fixed anymore.
You need a new fax machine due to the fact that the spare part is more costly than  a new one!
Jan 27, 2008 | Brother IntelliFAX 1800C All-In-One...
184 people viewed this tip
jasbo
jasbo
