Tip & How-To about Video Game Consoles & Games
Sony ps3 won't load,start,read disc
Clean with Compressed Air
One way to clean your PS3's internal laser is to use a can of compressed air. This is highly pressurized air contained in a can with a thin nozzle on the end. It is designed to get dust and dirt out of small spaces. Cans of compressed air can be purchased at any major electronics retailer, such as Best Buy or Radio Shack. Point the can's nozzle toward the PS3's disc tray and lightly spray for a few seconds to remove loose dust from the lens.
Use a Laser Lens Cleaner Kit
Also available are laser lens cleaning kits that work with the PlayStation 3. These kits contain a disc that is inserted in the PS3 the same way you would a video game or movie. The difference is that there is no data on the disc; it is designed specifically to spin in such a way that it gently cleans that PS3's laser lens, removing all dust, dirt and smudges in the process. These kits will also work on DVD, Blu-Ray and computer disc drives, in addition to the PS3.
Maintain the Discs
One way to make sure your PS3 laser stays clean is to keep track of the discs themselves. Examine a disc before you put it into your PS3's disc tray. If there is any dust or dirt use a dry, soft cloth to gently remove them before play. Dust and dirt are easily transmitted to the PS3's laser lens as the disc spins around at high speeds in the tray. By keeping the discs clean, you can make sure you don't have to go out and spend extra money on cleaning your PS3 laser lens in the first place.
Video Game Consoles & Games Logo
KTM SX50 wont run without choke
carb is running tooo lean, remove carb and strip down, removing all internal jets, check float height setting and note number of turns mixture screw is set at.......completely clean internals in a large can of carb cleaner- available at wall mart- has a basket inside the metal container so you will not loose small parts while the carb is soaking in the mixture...leave for a day, the crean all parts and blow out with high pressure compressed air. and re-assemble, and refit.....please note, never use ethanol fuel in your motorcycle, I only use classic gas in all my vehicles...less problems
Dec 27, 2013 | 2009 KTM 50 SX
ps3 hot
Get a can of compressed air and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it.
Jun 25, 2012 | Sony PlayStation® 3 (80GB) Console
How do you clean the table fan?
You can use a brush with assistance from high pressure compressed air- from a Air compressor or if you reverse the vaccum cleaner ports available in some models.
While the air is blown brush to clean the grill and blades. Use a face mask so as not to inhale the fine dust. Finally clean using a degreaser spray like WD40.
Jul 01, 2011 | Honeywell HT-800 Table Fan
i have an inner cooler and i vacummed it but it is still shutting off why?
the fan itself might be full of dust internally, means opening it and cleaning the internal fins to create airflow again. does sound like a heat issue though, most likely caused by poor internal airflow.
if you didn't want to take it apart to clean it, you could also try a can of compressed air (air shot), can be purchased from most high street shops like PC WORLD, Currys, Dixons, Circuit City, ect. and the cans of compressed air don't cost much.
If you do try compressed air, it comes out the can VERY cold so de let your PS3 cool down to room temp on its own before you use the air, otherwise you will cause rapid cooling and could crack the motherboard.
I do hope I have helped.
Jan 01, 2010 | Sony Playstation 3 (PS3) Console
Compressed air Vs vacuum cleaner for filters?
don't clean with compressed air, you will contaminate the air you breathe. I just bought a small ShopVac with an 18-foot hose to clean exactly what you're describing
Feb 21, 2009 | NEC VT470 Multimedia Projector
493 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
