Tip & How-To about Computers & Internet
Laptop battery life tip
Extend your battery life on your laptop, do not leave it plugged in and charging all of the time. When a laptop is constantly charging, it will deplete the cells on the battery. Two ways to combat this, charge your laptop fully and remove the battery while it is plugged in, or you can run your laptop on battery power a few times a week until the battery dies.
Computers & Internet Logo
does leaving my camera on the charger kill the battery?
Hey there,
The answer is yes. The life of your battery is shortened every time you charge it. If you leave it on the charger, it will stop charging when full, but constantly attempt to top it up to full charge.
The best way to extend the life of your battery is to charge once the battery is near depleted.
Oct 03, 2013 | Nikon COOLPIX L6 Compact Digital Camera...
what will happen if the battery in your laptop is not fully charging
That would mean your battery is dying and you need to go buy a new battery for your laptop. You can buy new batterys for around $40
Find a store that sells laptop parts or go online look on amazon or next tag also when you get your new battery plugin your laptop charge your new battery so it has a full charge.Then when it is done charging unplug it and use the battery until it dies, then plug it in again to recharge it never leave it plugged in if it is fully charged for long periods.if you are using your laptop at home you can pull out the battery and use it when its plugged into the wall this will help to extend your battery life just make sure you have a fully charged battery before leaving your house. always unplug your your laptop when its is fully charged this will also extend your battery life for along time
Sep 26, 2012 | HEWLETT-PACKARD Hewlett Packard Battery...
my laptop doesn't read the battery? what could be the problem?
First, check to make sure the battery is properly inserted.
Second, how old is your laptop? Batteries in laptops only have a certain lifespan. If you leave the battery in the laptop for prolonged periods of time while it is plugged in charging and the battery is at 100%, the life span will significantly degrade over time due to the constant charge/discharge.
Aug 22, 2011 | Averatec 4200 Notebook
187 people viewed this tip
David Payne
David Payne
