Tip & How-To about Cell Phones
Nokia Default Security Lock Code
All Nokia Cellphones has its own security lock code if you are accessing to activate it's security module and change it to your prepared PIN or Lock Code.
If your are trying to activate the Phone lock status or Phone memory lock status, it will require you to type the default security lock, just type the number below
Default Lock Code: 12345
Note: This code is only applicable if it is the first time for your phone to change its security code
Cell Phones Logo
i can't change my security code hw can i change it ? it is 12345 the dafualt one , and i want to change it how ?
I suggest you leave the security code alone, it is used to clear the phone call logs etc.
I recommend to put a pin code on the SIM card to lock your phone's keyboard. When you open your phone or unlock the keypad to access the phone's menu etc. then you need to enter the 4 digit pin code. This also prevents anyone accessing your phone unless they have this pin code.
Sep 09, 2011 | Nokia Classic 2700 Cell Phone
Lock Code, Pin Code & PUK code
Omg i 4got my PUK wat cani do ,,,,,,,,,,,,,Do i have to go to dey operator.....is dere a nother way???79a2dcb.gif
Jul 30, 2007 | Nokia E61 Smartphone
my standard lock code was changed is there anything i can do
Contact your cellular service provider and ask for Tech Support. They'll ask for your account password. They can then give you a security override code which you will enter on your phone's keypad. This will give you access to your phone to enter a new PIN.
We cannot provide security codes at FixYa as we are unable to verify ownership of cellphones.
Jan 16, 2011 | Nokia E71x Cell Phone
I want your phone locker?
You can set up a security code to lock your Nokia 6288 keypad in case a thief tries to call from your stolen phone
Published on Mar 14, 2007
You can set up a security code to lock your Nokia 6280's keypad in case your phone opens in your pocket and calls one of your contacts, annoying them and potentially running up a huge bill.
The code will also stop a thief from using your stolen Nokia 6280 to run up a huge phone bill before you can alert your network provider.
To set the security code, click Menu > Settings > Phone > Security keyguard. You'll be prompted for the Security code. By default this is 12345. Enter this and press OK. Select On and click Select to see the message 'Security keyguard activated'.
Now when you slide your phone shut and press Lock, you'll see the message 'Keypad locked with security code'.
When you slide it open, you'll be prompted to enter the security code. Type your code and click OK to activate your keypad.
Of course, if any potential phone thieves are reading this, they'll now know the default security code is 12345.
To change the security code, go to Menu > Settings > Security > Access codes > Change security code. When prompted, enter your current security code and click OK. The enter your new security code (a PIN between 5 and 10 digits in length), click OK and enter the new code again to verify it. Click OK and you'll see the message 'Security code changed'.
Hope this helps.
Jan 12, 2011 | Nokia Lands Phones
Security code for Nokia 2100
The main code used in Nokia phones is :
#pw+(master code)+Y#
This code is able to check, activate or remove Sim card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
(master code) is a 10 digit code, based on the phones IMEI number.
Eg. To remove restriction on lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
Bypass the SP lock With a Nokia 16xx/21xx/31xx/51xx/81xx
1. Insert SIM card of different provider.
2. Turn on the phone and press the UP VOLUME key for 3 sec.
Then release it and the phone says PIN CODE?
3. Press the "C" key.
4. Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone now says: PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again.
NOTE: On version 5.04 Nokia has removed this option !
Dec 17, 2008 | Nokia 2100 Cellular Phone
227 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
