Tip & How-To about Computers & Internet
Calculate more in Windows 7
At first glance the Windows 7 calculator looks just like Vista's version, but explore the Mode menu and you'll see powerful new Statistics and Programmer views. And if you're clueless about bitwise manipulation, then try the Options menu instead. This offers many different unit conversions (length, weight, volume and more), date calculations (how many days between two dates?), and spreadsheet-type templates to help you calculate vehicle mileage, mortgage rates and more.Don't take any Windows 7 applet at face value, then - there are some very powerful new features hidden in the background. Be sure to explore every option in all Windows applets to ensure you don't miss anything important
Computers & Internet Logo
Is there any possibility of making this printer compatible with windows 7
With Windows 7, I found that installing the Vista software/drivers in the compatibility mode works well.
Right click on the setup.exe file, left click properties, left click compatibility. Change the compatibility to Vista(Try Vista SP2). Then install the proper drivers. You'll be prompted when to connect the printer(powered on).
***To install drivers, sometimes the file unzips and does nothing. You have to look for the setup.exe file, right click on it, then left click run as administrator***
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Scanning
Scanning using USB connection, open the Dell All-In-One Center, click on scanning and copying and scan from there.
Scanning wirelessly, use the scan buttons on the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 01, 2011 | Dell A940 All-In-One InkJet Printer
how to instal outlook express?
Outlook express only comes with windows xp and earlyer windows versions.
However in windows vista microsoft did replace outlook express with windows mail and
in windows 7 they left it completely out of the package.
In windows 7 you'll have to install windows mail from the windows live essentials package, wich is free to download.
Outlook express can't be installed on windows vista and 7, use windows mail instead.
Download Windows Live Essentials here: http://explore.live.com/windows-live-essentials?os=other
May 22, 2011 | Microsoft Office Professional 2007 Full...
when i turn on my zune it just continues to restart. it showed a code 5 error message. What is it and can i fix it
you receive the message when A Windows Digital Rights Management component is corrupt.
Things to try
  1. Reset the DRM system on the computer. Warning This procedure affects all media files on the computer that use Windows Media DRM technology. The effect of this procedure is not limited to media files that you obtained from the Zune Marketplace. If you follow this procedure, content licenses for all protected media files on the hard disk are deleted. Other providers, such as, Napster, MSN Music, and Wal-Mart, use different mechanisms for restoring licenses. If you have content from other providers, examine the appropriate license restoration policies before you continue.To reset the DRM system on the computer, follow these steps:
    1. Verify that the Show hidden files and folders option is turned on. To do this, follow these steps:
      Windows 7 or Windows Vista
      1. Start Windows Explorer. To do this, click Start, type userinit.exe in the Start Search box, and then press ENTER.
      2. Click Organize, and then click Folder and Search Options.
      3. Click the View tab.
      4. Click Advanced Settings.
      5. Under Hidden files and folders, click Show hidden files and folders, click to clear the Hide Protected Operating System files (recommended) check box, and then click OK.
      Windows XP
      1. Start Windows Explorer. To do this, click Start, click Run, type userinit.exe, and then click OK.
      2. Click Tools, and then click Folder Options.
    2. Locate the DRM folder on the computer. Typically, the DRM folder is located in the following location. Note In these paths, drive represents the drive on which Windows is installed.Windows 7 or Windows Vista
      • Windows 7 or Windows Vista x86-based versions
        drive:\ProgramData\Microsoft\Windows\DRM
      • Windows 7 or Windows Vista x64-based versions
      Windows XP
      • drive:\Documents and Settings\All Users\DRM
      Note If you have upgraded from Windows 98 or from Window ME to Windows XP, the DRM folders may be located in C:\Windows\DRM.DRM folders can be located in various locations in different versions of Windows. You can also locate the DRM data path in the registry. DRM data is located in the following section of the registry:
      • x86-based versions of Windows XP, Windows Vista, or Windows 7: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      • x64-based versions of Windows 7 or Windows Vista: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      To locate the DRM path in the registry, follow these steps:
      1. Start Registry Editor.
          Windows XP
          • Click Start, click Run, type Regedit, and then click OK.
          1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, type run in the Start Search box, and then click Run under Programs.
          2. Type regedit.exe in the Open box, and then click OK.
            Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
      2. Look for the applicable folder based on the version of Windows that you are using.
    3. Rename the DRM folder to DRMbackup.
      1. Right-click the DRM folder, and then click Rename.
      2. Type DRMbackup, and then press ENTER.
      3. Close Windows Explorer.
        If you receive an “Access denied” error message when you try to rename your DRM folder, start the computer in safe mode and log in as the computer administrator. To do this, follow these steps:
        1. Restart the computer and start pressing the F8 key on your keyboard. On a computer that is configured to start multiple operating systems, press the F8 key when the Boot menu appears.
        2. Select the safe mode option when the Windows Advanced Options menu appears, and then press ENTER.
          The Boot menu appears again and the words "Safe Mode" appears in blue at the bottom of the screen.
    4. Reset the DRM security component. To do this, visit the following Microsoft Web site, and then follow the steps to upgrade the DRM security component: http://go.microsoft.com/FWLink?LinkID=34506 (http://go.microsoft.com/FWLink?LinkID=34506)
      Note When you access this site through Internet Explorer on a Windows Vista-based computer, you may receive a "user account control" popup message that requires that you enter the administrator password to continue. Note If you are running a 64-bit version of Windows 7 or Windows Vista x64 and the Upgrade button on the site listed earlier in this step appears dimmed, you will have to start Internet Explorer by using an account on the computer that has Administrative privileges in order to continue.
    5. Sign in to the Zune Marketplace. Then try to play a song to verify that the issue has been resolved.
    6. Restore the setting of the Hidden files and folders option. To do this, follow these steps:
Oct 31, 2009 | Audio Players & Recorders
171 people viewed this tip
David Payne
David Payne
