Tip & How-To about Computers & Internet
IGoogle - Check this Google lovers
IGoogle
www.google.com/ig Not too long ago, iGoogle was better known as Google Personalized Homepage. iGoogle lets you create a customized homepage that you can set as your browser's default page with all you want to see when you fire it up.
Add The Weather Gadget
One of the gadgets you can add to the iGoogle page is Weather, which gives you a forecast for the next few days, along with other information like wind speed and humidity. The Weather gadget is usually on by default; if it isn't, click on Add Stuff. Here you'll find Calendar under the popular section. Click on “Add it now”. Go back to the iGoogle main page. Click the drop-down button under Weather, and click Edit Settings. Select UK as the Country/Region and choose your city. Click Add and then Save.
Change The Theme
Google recently added theme support for iGoogle. Google also gives you with a nice bunch of themes to choose from. Click on the “Select theme” link. Choose one of the themes and click Save. Certain themes change with the weather in your region, so you might have to enter your city name.
Move Gadgets Around
Gadgets can be moved around the page. This means you can have the more important gadgets on top and the less important ones below. Moving gadgets can be done by clicking the title bar of a gadget and dragging to its destination. The gadget will automatically dock alongside the other gadgets.
Make Your Own Gadgets
Google gives you a base to start off with your own little Gadgets. To add your own Gadgets, click on Add Stuff. Then, click on “Create your own gadget”. You will come to a page with an option to choose between some seven presets. Click on a preset suitable for the Gadget you’re planning on making. Enter the information for that Gadget and click on “Preview gadget” to get an idea of what it will look like. If you're pleased with the results, click on “Create gadget”.
Add A New Tab
If you reach a point when there are too many gadgets in your iGoogle page, you can choose to put the less important ones in a new tab. Click on the “Add a tab” link. You will be asked to enter a name for the tab. Once the tab is created, you can click on Add Stuff to add new Gadgets to that tab. You can also move Gadgets from one tab to another by clicking the title bar of the Gadget and dragging it into the tab name.
Add Feeds To iGoogle
iGoogle lets you do some basic feed reading as well. The steps are similar to adding Gadgets. Click on Add Stuff. Click on “Add by URL” next to the search button. Enter the URL for the feed and click Add. Next, click on Close, and go to the main iGoogle Page. You will find the feed listing there. You can change the number of news items displayed by clicking on the drop-down and selecting “Edit settings”. Use the drop-down to change the number of news items and click Save.
View Gadget Source
Anyone can view the source code for Gadgets. Click on the drop-down in the title bar of a Gadget and click “About this gadget”. A new page with comments from users will be displayed. Click on the “View source” link to view the source for the Gadget. On the right panel, lists of similar gadgets are displayed for you to choose from.
I have many more Tips for iGoogle, Please post some comments if you need more help regarding......
Computers & Internet Logo
how do you make an igoogle account
You can create an iGoogle account by visiting http://www.google.com/ig
Once on the page you will need to sign in with your existing Google account or create a new Google account. Once signed up and signed in you can add the widgets you would like and customize the page like you want.
Hope that helps!
Apr 24, 2012 | Microsoft Computers & Internet
I have ask.com as my default when I go out on the Internet. How do I change it to google.com as my default so ask.com does not come up.
go to google.com on the search engine, on the search page it should show a gmail sign up & to the left of the page it should show make google your homepage, just follow the prompts
you can even put a icon on your desktop of google,,when your on your google home page--right click the google name & go to create shortcut, & it should put a shortcut to igoogle on your desktop,,that's what I did
to check to see if igoogle is your home page do the following steps
Go to the start menu
Then to control panel
Network & internet connections
Go to OR PICK A CONTROL PANEL ICON
Click on internet options
The menu should show--internet properties
In the general tab at the top should be home page
Check to see if google is there for home page
If it's not type it in--igoogle & click apply & ok
Sep 21, 2011 | Computers & Internet
My home page changed to iGoogle which involves using ore key strokes to search a site. I want it back to Google the way it was before.
go to google.com and then use tools of your browser---internet options--use current web page as your home page--click apply--ok
that should work.
Oct 28, 2008 | Computers & Internet
268 people viewed this tip
David Payne
David Payne
