Tip & How-To about Baby Care
Hello. Here is a great weekend project that anyone can succeed with. Under cabinet lighting is such an enhancement to the function and cheerfulness of your kitchen. My most recent experience with this was very successful. The kitchen really needed the extra light and, the home owner let me choose the fixtures. I selected Utilitech line Voltage Xenon Lights from Lowes. These units come in three lengths, 12", 18" and 24". They can operate alone or in groups, they use 110 volts and no transformers, and they have a high/lo/off dimmer switch built in. Finally, they can be installed using the enclosed plug-in cords, or direct wired, and you can link up to 600 watts. A twelve inch bar is 40 watts. All of that said, all you need to proceed is about 45 minutes per cabinet, and the following tools: electric drill and a set of wood flat drill bits, flat head screwdriver, philips screwdriver, wire cutters, wire strippers, pliers, safety glasses and a small mirror. The mirror will assist you in tightening the screws as you install the fixtures under the cabinets. Turn off the power at the breaker for the circuit you are working on [unless of course you are going to use the plug in cords included in the box instead of direct wiring]. VERY USEFUL TIP: probably the most difficult part of this task could be mounting each of the light bars uniformly under the cabinets. Recognizing this, I made a template for each of the three lengths of fixture so that I knew exactly where to predrill and start the two mounting screws required per fixture. These templates were made from still cardboard, cut with a razor blade knife, although you could have used 1/4 inch plywood just as well.
Baby Care Logo
I want to make my dog a bed and wondered what would be the best materials to use?
Take 2 old cushions and sew them together then get a pillow slip and cover the two cushions and make them one big one - hey presto a cheap and easy dogs bed he/she will love it.
May 13, 2012 | Dogs
Can anyone tell me approx. how much it is to fix a convergence problem on a Toshiba 46'' 46H84 tv? Would it be over $300.00?
Hello, If you were able to do the job yourself the part runs around $80 to $100 but this would require you to understand how to solder. I would say if you this is the case it would be worth fixing. If you took the tv to a repair man it would run you somewhere around $400 to $600 to have it repaired. Im sure you know how much these cost and know that you could buy a better tv for that kind of money. I hope my information was helpful and if it was please dont forget to rate my answer. I hope you have a great weekend. :>)
Jun 12, 2009 | Toshiba 46H84 46" Rear Projection...
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
512 people viewed this tip
Top Baby Care Experts
masud
masud
Tom Chichester
Are you a Baby Care Expert? Answer questions, earn points and help others
