Tip & How-To about Computers & Internet
Don't trash that computer! Restore it!
Just because a computer slows down and or starts having errors does not mean it's ready for the trash. I talk to several people a week who have problems out of a computer that is only a year or two old, and rather than getting it repaired they go out and spend another $500 to $600 to replace it.
Many Computer Service companies now offer Computer Restoration Services where the computer operating system is reloaded, clean the dust from the inside of the computer, and load the most up to date drivers. Then the computer runs like when when it was new, or even faster. That service usually runs around $150. That is a savings of over $350.
The service mentioned above does not include replacing bad hardware, I have found that most issues are caused by bad configuration or Operating System corruption not hardware. Computer Restoration service will take care of both of those issues.
These days we all have to save money every where we can. So don't trash that year or two old computer! Restore it!
Computers & Internet Logo
Considering canceling my TalkTalk account
If you go with BT, they can't blame anyone else as it is Bt's cable, fibre and exchange that is in use.
Mar 09, 2017 | Computers & Internet
i was shooting yesterday with Canon 50D & a lens 18-55 & the camera started to give me error code 20; telling me switch OFF & ON or re-install your battery. i removed the battery & put it again, then i removed it & put another one. it kept doing that error 20 every 2 continues shots & i didn't know what to do ?! Pls advice Thanks
Error 20 didn't show up on a 50D error code search, however I've run into this before when the processing operation couldn't be completed meaning the memory card was corrupt.
The Canon 50D makes massively large files and several things can run you into problems the first I doubt but need to list and that is you are using a card with a slow write speed. Another is that you have been using that trash can icon and not formatting your memory card. The trash can deletes files yes but it leaves what I cal a residue (small amount of data) do this enough and your card fills with useless data. Still looking at the memory card, you possibly downloaded pictures to the computer and formatted the card in the computer, not a good thing to do. Error 20 is also a windows error code for corrupt files which will play havoc with your camera firmware.
Another possibility is you downloaded picture files to your computer and forgot to do a safe disconnect, eject or safely remove device what ever your camera computer uses for shut the device off before disconnecting.
After downloading your just placed the memory card back into the camera and maybe started shooting again with a "dirty" card. The correct practice is to format your memory card every time you have had it connected to the computer. Format not delete, format the memory card in the camera it is to be used in.
Clean up the card and your problem will go away. Error 20 is a processing problem, corrupt file(s) or a camera firmware problem. If the problem continues do a firmware update to your camera through the canon site it's free
Jan 20, 2011 | Cameras
my new desktop is so slow..........I want to throw it in the trash. (bought 6 weeks ago from Tiger direct.ca) Do you have a solution?
There can be a number of things that are slowing your computer down. First queston is, are you talking about it not running fast on the internet of in general running slow. I am going to take it your talking about it running slow over all. With new computers they (the maf.) but a lot of unecssary software in the "Start "", that really slows down the computer. I am going to tell you how to take care of this problem.
Go to Start-Run, when the winodw pops up type MSCONFIG (it looks like a lot of stuff, but's it only a teddy bear), go to the START UP TAB. You will see check markes next to all the software that is starting u and using a lot of system memory. Yo simple uncheck the ones you do not want to run at startup, now when you uncheck these the program will still run, but only when you tell it to,
When you have selected what programs you want to or do not want to run, Click on APPLY and then OK. The computr will restart and should begin to run faster.
When you have completed this, please let me know how it's working, and if still slower than you think it should be, then we will go to the nextstep.
Jack
Jun 13, 2008 | Acer Computers & Internet
114 people viewed this tip
David Payne
David Payne
