Tip & How-To about Computers & Internet
Use ReadyBoost to Speed up Programs in Windows 7 To enable ReadyBoost: 1. Put your USB thumb drive into a USB port on your computer. 2. When the AutoPlay menu appears, click Speed up my System with Windows ReadyBoost. 3. Select your device and specify how much of the drive you want to use for ReadyBoost. I recommend using a full USB drive. (TIP: match the size of your drive to the amount of RAM you have in your computer. i.e., With 4GB RAM, use a 4GB thumb drive 4. Click OK. Don?t expect miracles?but stick with it and your computer will begin to perform more efficiently.
Computers & Internet Logo
pen drive is slow
Slow Transfer on a USB Flash Drive b> Using a USB flash drive is a convenient way of transferring data and files from one device to another. However, sometimes you may find that your USB drive is slow to transfer files onto your laptop or PC. This lag may also cause your desktop or laptop to slow down while you use other programs. You do not need to replace your flash drive and buy a new one. You can fix a slow file transfer problem in just a few steps.
b>Plug your USB flash drive into your computer. Click the "Start" button and select "My Computer." Right-click the USB icon from the My Computer window and click "Properties" from the menu that comes up. Go to the "Hardware" tab and select your flash drive once you find it in the list of items. Then click the "Properties" option in this menu. Choose "Policies" tab within the Properties menu. Turn on the performance optimization option and click "OK." Click "OK" again to exit out of the Properties dialog box. Go back to the My Computer window and right-click on the USB icon. Select the "Format" option from the list of choices. Select the "NTFS" file system and choose "Quick Format." Press "OK" to confirm the choices and to initiate the formatting. Wait for the drive to finish formatting before ejecting it and removing it from the computer.
USB Flash That Is Slow and Damaged
b> USB flash drives are used to transport data between computer systems. Because it is essentially just a small hard drive, the USB device can become damaged and slow down in performance due to viruses or damaged files. To correct these problems and fix the USB flash drive, you must reformat the drive. This removes all data from the drive, returning it to its factory settings.
Plug the USB flash drive into a USB port on the computer system. Close any AutoPlay window that may load onto the screen. Click "Start" then "(My) Computer." Right-click the removable device icon that appears on the screen. Select "Format" from the pull-down menu. This loads a format options screen. Click "Yes" and the computer formats the USB flash drive, removing the damaged content and returning it to the factory settings.
ReadyBoost With a Slow Flash Drive
b>The ReadyBoost feature in Windows has the ability to increase the speed of low-RAM computers by caching program data on a flash memory device. However, the device must meet minimum performance characteristics in order for Windows to enable ReadyBoost, because ReadyBoost may not meet expectations when used on a slower device. If you still want to use ReadyBoost with your flash drive or memory card, you can make a change in the system registry to force Windows to use the device.
Insert the flash device that you would like to use for ReadyBoost. Open the Start menu, and click "Computer" to see the icon for the device. Right-click the icon for the flash device, and then click "Properties." Click the "ReadyBoost" tab at the top of the window. Clear the check from the "Stop retesting this device when I plug it in" box, and then click "OK." Remove the flash device. Open the Start menu again. Type "regedit" in the "Search programs and files" box at the bottom, and then press "Enter" to run the Registry Editor. Double-click the folders "HKEY_LOCAL_MACHINE," "SOFTWARE," "Microsoft," "Windows NT," "CurrentVersion." and "EMDMgmt." Locate and click the folder for your flash memory device under "EMDMgmt." In most cases, you can determine the correct folder because it contains the name of the device's manufacturer. Double-click the registry entry "DeviceStatus" on the right side of the window. Change the number under "Value Data" to "2" and click "OK." Double-click "ReadSpeedKBs" on the right side of the window. Change the value to "10000000" and click "OK." Repeat this process with the "WriteSpeedKBs" registry entry and close the Registry Editor. Reinsert the flash memory device, and return to the "Computer" window. Right-click the icon for the flash memory device, and then click "Properties." Click the "ReadyBoost" tab. Windows now displays an option to enable ReadyBoost on the device. You might install a usb 3 card the speeds are much faster cheap and easy to install. Hope this helps.
Jan 08, 2013 | Electronics - Others
when i turn on its taking time to get my disk that is my proplem
the best way is to upgrade ur PC , or format your harddisk or apply this settings as follows ===
Speed Up Windows 7 Boot Up Time Don't Try This To Make Windows 7 Faster:
Try ReadyBoost:
  • 1. Speed Up Windows 7 Using ReadyBoost
  • 2. Check ReadyBoost
  • 3. Speed test your SD Card, CF Card, Flash Drive, HDD
Speed Up Windows 7 BootUpdate 04/21: This tweak does not seem to have great effects on your boot time. Instead use a startup programs manager for Windows 7 and remove as many startup programs as you possibly can.
Do you have a dual-core or quad-core processor? Great, let's lower the boot time of Windows 7:
1. Click on Start, enter "msconfig" into the search field
2. Open the "boot" tab
3. Click on Advanced
4. Check "Number of proccessors" and select "2′ or "4′ from the dropdown menu. (obviously, you can only select it if you have a dual-core/quad-core).
Full Image
Speed up Windows 7: Change Taskbar Thumbnail Preview Time1. Click on Start, enter "regedit" into the search field.
2. Goto: HKEY_CURRENT_USER\Control Panel\Mouse
Speed Up Windows 7 Taskbar Thumbnail Preview
3. Double-click on "MouseHoverTime" and change the value to 100 or lower:
Change the mouse hover time to 100 or lower
4. Voilà, your thumbnail previews should appear a lot faster now. For another great tweak to speed up the Windows 7 taskbar, click here.
Speed Up Windows 7 Shutdown Time1. Open the registry editor (enter regedit into search field)
2. Go to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control"
3. Lower the value (12000 is the default value = 12 seconds) to a value of your choice
Speed Up Application Access - Increase your productivityFirst of all create a folder "QuickStart" somewhere on your PC. Right-click on your taskbar:
toolbar.jpgLocate the folder "QuickStart" (you just created the folder so yo should know where it is) and then click "Ok". You are almost done, but we don't want that ugly text on our taskbar that is using a lot of space, turn it off:
texttitle.jpgRight-click on the new toolbar and uncheck "Show Text" and "Show Title"! Now drag the toolbar to the left until it's below the main icons and you will have something like this:
Sep 01, 2011 | Acer Computers & Internet
usb drive use
Most thumb drives are used like floppy or rewritable optical discs (excluding ReadyBoost and the bootable versions). They are most often formatted as FAT drives (under Windows). If the drive is good and the USB port is good, plugging the drive into the computer's port should trigger a "new hardware found" message from Windows.
In Windows, open My Computer or Computer (depending on the OS) and you will see it listed under Drives with Removable Storage. You can use the file explorer to navigate through your regular drive and copy files to the thumb drive or the reverse. (I usually open two different windows and drag the files with a right-click then select Copy.) Synch programs can let you keep the thumb drive and hard disc copy at the same version. Alternatively, you can save a file directly from the program that you are usng to edit the material. (File > Save As and chose the destination). You can also open the file from the thumb drive in a similar mode. To avoid lost data, always select the Safely Remove Hardware from the taskbar (or Eject from the File Explorer) before unplugging the drive from the port.
The biggest problem is that the FAT formatting limits the number of files you can put on the disc unless you keep them in folders. (The same number of folders can be in the home directory as files without using folders.)
Bootable thumb drives (as well as those that can run software directly from the USB drive) come with software that lets them do this. Then they act like any optical disc with Autorun and executable programs. Readyboost is dealt with completely by the OS and keeps the drive (or portion of the drive) separate from the area that will store files.
Sometimes these drives do fail. Getting the data off the flash memory takes a professional most of the time.
I hope this helps.
(You can copy all of the files from the thumb drive and reformat it at intervals. Then copy files back if you are concerned about file fragmentation.)
Jul 24, 2010 | Verbatim VER95327 USB Hard Drive
223 people viewed this tip
David Payne
David Payne
