Tip & How-To about Computers & Internet
Useful Notepad Trick !
This is real cool for people who use notepad to write down any info on a day to day basis.
Open a blank Notepad file
* Write .LOG as the first line of the file, press enter.
* Save the file and close it.
* Double-click the file to open it and notice that Notepad appends the current date and time to the end of the file and places the cursor on the line after.
* Type your notes and then save and close the file.
Each time you open the file, Notepad repeats the process, appending the time and date to the end of the file and placing the cursor below it.
Computers & Internet Logo
how to delete notepad logs
Something is running on your computer and writing to those log files. You could try booting into safe mode (F8 on startup) and see if you can delete them. There are other things you can do to delete them but they will take a lot more time to explain and do. If they are that important to delete please reply and I'll get you the info you need.
Nov 29, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Unable to connect to localhost 2864 upon attempting Sony Bloggie MHS-TSS20 CAMCORDER. NEED HELP. WAYNE
Chatted with a Sony tech who told me to do the following which worked for me:
Log into the computer as the Administrator.
On the computer, browse to the C:\Windows\System32\drivers\etc folder.
In the etc folder, open the hosts file using the Notepad software.
At the bottom of the hosts-Notepad window, delete ::1 local host line from the file.
If there is a # symbol before the 127.0.0.1 IP address, delete the # symbol.
On the hosts-Notepad menu bar, click File.
In the File drop-down menu, click Save.
Close the hosts-Notepad window.
Next, try to open the Bloggie Software on the Computer.
Mar 11, 2011 | Sony MHSTS10B Bloggie Touch High...
localhost: 2468/ index. html
I plug in the bloggie & it gets me to this website Why????
Dec 29, 2010 | Sony Cameras
burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
149 people viewed this tip
David Payne
David Payne
