Tip & How-To about Washing Machines
FH Error Code
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the "FH" error code.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
I hope this helpful. Please post back if you can't find the tech sheet and/or need further assistance.
Washing Machines Logo
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
F21 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This helped my husband fix our washer. We had 5 baby socks clogging up the washer from draining. I guess we will need to use a laundry bag to wash little baby things.
Apr 05, 2010 | Kenmore Elite 45986 Front Load Washer
This fixed my problem exactly! baby clothes had wound up in the trap... ugh
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
what does f21 on washer mean?
Hi, this advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Take care
May 31, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
FH Error Code on Whirlpool Duet & Kenmore Elite Front Loaders
Great advice and steered me in the right direction for solving my problem. here's some additional things to look for and try.
1. There are two inlet valves at the back left of the washer when you take the lid off. These two inlet valves are one big blue plastic part. Each valve has two wires going to it. Your hot and cold water hoses of course connect to these valves from the outside of the machine, at the back left. This F/H error can also be caused if one of the valves is not working and not allowing water to come into the machine during some part of the cycle. At the beginning of a wash cycle it is trying to allow hot water in, and then after about 12 minutes it is trying to let cold water in at the beginning of the rinse cycle. If one or both fail to open then you will see the F/H error.
2. You can trouble shoot these valves by disconnecting one of the wires to one of the valves at a time and seeing what happens. For example, if you run the rinse and spin cycle it will want to open the cold water valve. When the valve opens you will be able to hear it. If you hear it and no water comes out there is something wrong with the valve or it is clogged at the outside mesh filter - unplug the valve wires and try again and if the noise goes away then you know thats the valve that the machine is trying to activate. If you don't hear it activating then either electricity is not getting to it or its bust.
3. None of the above fixed my problem. As mentioned above you should check to make sure your taps are turned on (duh :-)). For me it was the new hoses i purchased. Unbeknown to me these hoses had a "flood control" feature which shut off the flow of water when the water flow came on too suddenly. I had apparently turned the taps on too fast after connecting them, spiking the pressure on the cold one and activating its flood control feature. Turning off the water and disconnecting and reconnecting the hose fixed the problem.
Happy hunting in your troubleshooting....
May 22, 2008 | Kenmore Elite 45986 Front Load Washer
2,009 people viewed this tip
Top Washing Machines Experts
