Tip & How-To about Washing Machines
New detergent Sheets are NOT a good idea for front load washers
In the last week i have went to many customers home to remove detergent sheets from washing machine pumps on front load washers.
Purex® Complete 3-in-1™ Laundry Sheets are now on my "DONT USE THIS PRODUCT LIST." As an appliance repairman, i have made lots of money removing these sheets from the drain pumps on front load washing machines. I was at one of those jobs today and the customer watched me pull 14 of these sheets out of the pump and up into the hose that leads to the pump. I tested the machine and it then worked fine.
About 1 hour later, the customer called me and was furious because as she was doing a load a laundry and the water would no drain out again. I went right back to her home and once again i found more of those sheets inside her pump, 5 to be precise. About an hour later, i was done doing a complete clean out of her washer to make sure this didnt happen again.
She will no longer use Purex® Complete 3-in-1™ Laundry Sheets per my recommendation.
The sheets were designed to keep you from wasting money on using too much soap with the added ease of it also being a fabric softner sheet. Dont be lazy and dont use these sheets in a front loader of any brand.
The problem is that small articles of clothing like baby socks, and these sheets, make it thru the front seal and make its way between the tubs and on to the pump. This does not seem to be a problem with top loading washers yet, but we will find out in the near future.
Levi Holiday
www.lartoday.com
Washing Machines Logo
Even though I keep the door open when not in use it smells when actually in the wash cycle. How can we fix this as it is embarrassing.........
Hi and welcome to FixYa. I am Kelly. The yellow line is usually a resul of iron particulate in the water the machine uses. There are a few thing you can try to clean the machine.
You will not find this one in any manual.
Put one cup of bleach and 1/4 th cup "dishwashing powder" straight into the tub and run an empty or "cleaning rags cycle" with HOT water. You can add the juice of a freshly squeezed lemon or use lemon concentrate also with that. You may initially have to do this for 2 to 3 cycles to get rid of the iron deposits. After that you should use one of the products below before returning to reugular wash cycles.
There are other producs out there that you should use per their directions once a month.
http://www.affresh.com/#/home
and http://www.tide.com/en-US/product/tide-washing-machine-cleaner.jspx
Also make sure you using HE washing machine detergents vs regular washing machine detergent. Here is just one example:
http://www.purex.com/detergents/ultra-purex-he
Thanks for choosing FixYa.
Kelly
Jul 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer leaves a yellow line on my white clothes
Put one cup of bleach and 1/4 th cup dishwashing powder straight into the tub and run an empty or "cleaning rags cycle" with HOT water. You can add the juice of a freshly squeezed lemon or use lemon concentrate also with that. You may initially have to do this for 2 to 3 cycles to get rid of the iron deposits. After that you should use one of the products below before returning to reugular wash cycles.
Kelly
Jul 22, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
what detergent brand do you suggest with front loading washer?
We use 2x ultra ALL due to having allergies in our family. It is free of perfumes and clear of dyes. We only use 1/4 of the cup (or less) that is supplied with soap container and double rinse. That's the great thing about these washers, they use alot less water and don't need the extra soap as well. Even with the double rinse, at the end of the full cycle, we still see an occasional soap bubble near the door. Hope this helps!
Mar 25, 2010 | Frigidaire GLTF1670A Front Load Washer
99 people viewed this tip
Top Washing Machines Experts
