Tip & How-To about Washing Machines
F27 Error Code
This advice is for Kenmore Elite and Whirlpool Duet FRONT LOADER washers displaying the “F27” error code.
F27 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. This is verbatim from the tech sheet. You will need to check to following:
1. First, UNPLUG the washer for at LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, proceed to step 2.
2. Check the drain hose and make sure it is not plugged or kinked.
3. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
4. Check/Clean Drain Pump Filter of foreign objects.
5. Check for Drain Pump Failure.
6. Check the Inlet Valve for proper shut off
7. Check the Pressure switch for proper operation.
Check the drain hose by removing it from the standpipe and pulling a vacuum on it with a shop vac. You may have an obstruction in the drain line or drain pump. It is also a good idea to check the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub and runs to the inlet side of the drain pump. This area can get clogged with small articles of clothing.
Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the rear of the washer with all the wiring running to it). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the clear tubing (air hose) is still attached. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. This may generate an F27 error.
The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. Look for obstructions in the clean-out trap and impeller area of the pump.
The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off. You need to ask yourself if you find standing water in the tub when not in use.
The “Sud” error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent, HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause an over suds condition.
NOTE: Knowingly or unknowingly using the improper detergent on these model washers MAY void your manufacturer’s warranty. Read all instructions and documentation that comes with the appliance, thoroughly.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a component failure (more commonly, the CCU or pressure switch).
I hope this information is found to be helpful.
Washing Machines Logo
water doesn't drain out. keeps getting 2 different errors F01 and F27. what does mean?
F1 is a pump drive failure and F27 is an overflow condition. Both point to a pump problem. Remove the front panel and unscrew the pump filter. Water will come out, so be prepared! If the pump filter is clean, you will likely need to replace the pump.
Kelly
Mar 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F21 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This helped my husband fix our washer. We had 5 baby socks clogging up the washer from draining. I guess we will need to use a laundry bag to wash little baby things.
Apr 05, 2010 | Kenmore Elite 45986 Front Load Washer
I have an f27 error on my washing machine. Can you explain to me where the pressure switch is? I have the front, back, and top off of the machine.
Error code f27 is OVERFLOW CONDITION.----------
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.----------
Check:----------
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
----------- This should help.Thank you.
Jan 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
3,386 people viewed this tip
Top Washing Machines Experts
