Tip & How-To about Computers & Internet
Upgrade your NEC ND-3500AG firmware here
I used to have one of these I had no problems however I am not sure if its the DVD burner that is causing you the problem. Feel free to download my old toolkit for the NEC ND-3500AG lots of great bin files and information including the best and latest firmware flasher.
I suggest changing your DVD Authoring Software I always use TMPGEnc v4.0 Xpress then convert the MPG2 into DVD-Video using
VSO's ConvertXtoDVD v0.5299b this is the freeware version however its much improved v4.0.6.316 is available to buy HERE it costs $35.
I have never had any AV synch or encoding problems using these two apps I always use VSO's own Patin Couffin for controlling the Burner you can even select this if you use Imageburn for ISO creation and burning as well
Computers & Internet Logo
this disc wasn't burned successfully make sure you
hi Names Rui, try downloading a new cd/dvd burner software and install it to your PC thier are many types of cd/dvd burner tryto search free ones at google here is one link that i will give you
http://download.cnet.com/Free-Easy-CD-DVD-Burner/3000-2646_4-10627009.html just download and install it. try it hope you like it.
Jul 19, 2011 | HP Compaq Presario C700T Notebook
I am getting an error message that says : could not preform end of disc-at-once
Hi Aubri,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not burn a DVD, chances are your DVD burner componet needs to be replaced. Good Luck.
  • If this helps resolve your issue, would you please rate the solution
Dec 29, 2010 | Gear Head 8XDVDEXT DVD External Slim...
i cannot get the dvds to burn it says drive not presant
Hi Bramam,
    • Reboot
Dec 28, 2010 | Gear Head 8XDVDEXT DVD External Slim...
My PLEXTOR DVDR PX-708A DOESN'T RECOGNIZE CD.
Go to Plextor.com and download the firmware update. If you have the 708A-UF model, make sure you install the firmware update using a USB cable. Using a firewire cable to do the update can cause a data corruption problem with the firmware update.
Feb 17, 2010 | Plextor PX-708A DVD±RW Burner
trying to test dvd finalization burning with nero 8
Not an exact solution to your problem, but I feel a better solution.
Let me explain.
I used to use Nero 7. Then it seemed to make mistakes all the time. Error this, and error that. Removed it, used registry cleaner, reinstalled it.
Fine for a while, then the errors came back.
This became very monotonous.
I started downloading ISO files, of different Linux Ubuntu operating systems. Recommended burner software was a free version. Infra Recorder.
I uninstalled Nero, and installed Infra Recorder.
Haven't had a problem in a year and a half!
Infra Recorder download page,
http://infrarecorder.org/
Apr 29, 2009 | Computers & Internet
287 people viewed this tip
Alun Cox
David Payne
David Payne
