Tip & How-To about HTC Hero Smartphone
Battery Tips for the Sprint HTC Hero.....
Battery life on cells phone, especially the hoard of smart phones coming out, can be very short, especially right out of the box. The following are some tips to extend the time between chargings for the Sprint HTC Hero (and probably the European Hero as well as the Verizon Eris).
• update your system software to version 1.56. To check which version you have, go to Settings > About phone > scroll to see software version. To update, go to Systems updates from the same menu, and select Firmware update.
• turn the brightness down of your screen. The brighter the screen, the more juice you use from the battery. Go to Settings > Sound and Display > Brightness.
• turn off bluetooth, wifi, GPS, and mobile web when not in use. I place these widgets on one of my screens to have easy on/off access. Go to (+) > HTC Widget > Settings. I turn off everything at night, turn on mobile web during the day, and turn on the others as I need them.
• turn off the "Always On Mobile Network" setting. Go to Settings > Wireless Controls > Mobile network settings > Enable always-on.
• limit the amount of push to sync email and other applications.
• turn of the automatic updates for apps like Weather, Facebook, Twitter, email. With the apps constantly checking and pulling data, the battery will drain much quicker.
I can usually go about two days between chargings with moderate use and three days with light use.
Good luck.
HTC Hero Smartphone Logo
LGxenon GR500 is the battery life short on this phone
Hi, it is not normal for a battery to run down as fast as that.
The battery's life you are using, there is a cell inside the battery that determines how the battery functions.
The battery cell might be too weak to carry the phone and you will need to replace battery.
When you get a new battery, make sure you charge battery for Six hours before.
Take care.
Jun 21, 2010 | LG Xenon GR500 Cell Phone
short battery life
I had the same problem when I first started using the Droid. Coming from using a regular phone to using a smart phone, I didn't realize just how much power these things consume and how I would have to manage what I was using. The first thing you should be aware of is the necessity to charge your phone every night, without exception! Second, you should turn off the GPS function and WiFi whenever you aren't using them. In the case of the WiFi, I find that I just don't use it anymore anyway due to the speed and reliability of the 3G network. Third, get some apps to manage the problem. You will need an App-Destroyer, that you can use to shut down apps that you aren't currently using but are running in the background further depleting your battery life. You could also use a battery widget, there are many, some that let you easily shut down Wifi & GPS. The biggest hog of power other than these is the screen. Make sure you set it to shut down as quickly as you can deal with.
Jan 13, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
battery goes flat overnight replaced battery still goes flat overnight
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you use a car charger, use a wall plug instead and replace the battery again; because a lot of car chargers can harm battery life…especially if that is all you’ve ever used. Also check the settings on the phone, if you have disabled power saving features that dim the screen after so many seconds then the backlight will drain the battery very quickly. Use name brand batteries and not the ones that come with the phone, the ones that come with the phone can often ****. Finally, make sure that you do not have a short in your wall charger and that the first time you use a new battery you charge it fully to begin with and don’t charge it again until it is completely depleted. Supposedly newer batteries do not have to be primed, but I find it is a good practice anyway. Use the charger that came with your phone, the voltage/amps are not always just right if using a radio shack special.
Jun 30, 2009 | LG Prada KE850 Cellular Phone
could not find on/off switch
The top right hand side button (the side of the phone, not the front) press for 5 seconds and phone will come to life, make sure battery is charged. marquiss
Apr 30, 2009 | Cell Phones
SANYO MM-5600
If you use a car charger, use a wall plug instead and replace the battery; because a lot of car chargers can harm battery life…especially if that is all you’ve ever used. Also check the settings on the phone, if you have disabled power saving features that dim the screen after so many seconds then the back light will drain the battery very quickly. Use name brand batteries and not the ones that come with the phone, Sometimes the ones that come with the phone can ****. Finally, make sure that you do not have a short in your wall charger and that the first time you use a new battery you charge it fully to begin with and don’t charge it again until it is completely depleted. Supposedly newer batteries do not have to be primed, but I find it is a good practice anyway. Use the charger that came with your phone, the voltage/amps are not always just right if using a radio shack special.
Nov 29, 2007 | Sanyo MM-5600
1,188 people viewed this tip
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
