Tip & How-To about Office Equipment & Supplies
How to clean the corona wire on Intellafax 2800,2810, 3800 machines
Does your brother printer or fax machine have bad printing such as very light print or spotty print. If you have these problems chances are you have a dirty corona wire. The corona wire is used by the printer to put a charge on the paper so the toner is attracted to it in the pattern that the laser draws out. Below are the directions to clean the wire.
1. Open the front cover and pull out the drum unit and toner cartridge assembly.
2. Clean the primary corona wire inside the drum unit by gently sliding the blue tab from right to left several times.
3. Return the blue tab and click it into the Home position.
4. Reinstall the drum unit and toner cartridge assembly in the MFC/Printer.
5. Close the front cover.
Be sure to return the sliding blue tab back to the home position next to the arrow or you will have dark streaks on your printouts
when receiving fax, it won't print
make sure the property settings for the fax are not on the Microsoft printer make sure it is set to the local usb printer
Jan 28, 2014 | Brother MFC-J625DW Wireless All-in-One...
brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Jul 03, 2009 | Brother MFC-7820N Printer
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
brother intellifax 4100 prints full page all black
Good chance the High voltage power supply is bad. Not worth repairing. A new unit costs about 259.00.
Aug 08, 2006 | Brother IntelliFAX 4100 Laser Fax
410 people viewed this tip
jasbo
jasbo
