Tip & How-To about Computers & Internet
Power calibration error.
1) Try to write the DVD with minimum speed such as 2x or 4x.
2) Reinstall the writing(burning) software (nero, Ultraiso, cdburner...)
3) Uninstall the software completely from registry using some kind of uninstaller(revo uninstaller is freeware) http://www.revouninstaller.com/revo_uninstaller_free_download.html
4) Use different version of the burning software or change the burning software
5) Disable IMAPI service. Control panel/administrative tools/services
6) Use cleaning lens dvd.
7) Reinsert the IDE and power cable of ur dvd drive attached to ur motherboard.
8) Check DVD drive in another computer. If it is working it would b problem in hardware or software.
9) Make sure the jumper of dvd drive is in master if hard disk is in master.
10)Make sure the upper and lower filters are deleted from the registry. U can use doug knox software to fix this or u can do manually by doing this. Run->regedit->HKEY_LOCAL_MACHINE->System->Current control set->class->{4D36E965-E325-11CE-BFC1-08002BE10318}
http://lh6.ggpht.com/_lH6HIoVNDJs/Sx3iQ7RdDpI/AAAAAAAAA3Q/a8sWV8GIyuM/s1600-h/Screen%20Snaper%20Image[18].png
Computers & Internet Logo
how can i burn an audio disc that will play on a cd player and not just my pc?
Modern CD players usually can read all audio disk burned on any computer system.
If you have an older model however you may experience some problem with certain settings, follow instructions below:
1 Ensure that you burn on CD support, and not a DVD, many computer drive can manage the same way CD and DVD, and burn music on DVD, but the player won't read them.
2 Ensure that you are burning an Audio CD on the cd burning, if you will just burn your MP3 files onto a disk, an ordinary CD player won't read them, unless it has MP3 capabilities.
3 If you have an old system try burning at the minimum possible speed , systems built in 80s and early 90s where limited to low speed, some 80s CD drive could read only 2x or 4x.
4 If your system is old also chose close disk after burning option on burning software, this wont affect new cd players.
You also need a software to burn CD, if you do not have burning software , see choice on websites below:
The Best, Free Alternatives to Nero CD/DVD Burner
15 Free CD/DVD burning alternatives to Nero
6 Free Alternatives To Nero | Into Windows
Mar 05, 2009 | Audio Players & Recorders
hl-dt-st dvdram gsa-t20n ata burn speed for cdr changes to 10x minimum automatic soon as i put a blank cdr in. i need to do slower burn Speed (4x) and i tried with different software and its always the same Thanks
Your drive doesn't support slower burning speeds unfortuately, here are the specifications for it:
Write Speed DVD+R 2.4x CLV, 4x ZCLV, 8x CAV DVD-R 2x CLV, 4x ZCLV, 8x CAV DVD+RW 2.4x, 3.3x CLV, 4x ZCLV, 8x ZCLV
(8x Speed disc: 3.3x CLV, 8x ZCLV)
DVD-RW 1x, 2x CLV, 4x, 6x ZCLV DVD-RAM 2x, 3x ZCLV, 5x PCAV(Ver.2.2) (16x Media: Not support) CD-R 10x CLV, 16x, 24x ZCLV CD-RW 4x, 10x CLV, 16x ZCLV
(High Speed: 10x CLV, Ultra Speed: 16x ZCLV, Ultra Speed plus: 16x ZCLV)
DVD+R DL 2.4x CLV, 4x ZCLV, 6x ZCLV DVD-R DL 2x CLV, 4x ZCLV, 6x ZCLV Read Speed DVD-R/RW/ROM 8x/8x/8x max. DVD-R DL 6x max. DVD-RAM (Ver.1.0/2.2) (Ver.1.0) 2x
(Ver.2.2) 2x, 3x, 5x
DVD-Video(CSS Compliant Disc) 4x max. (Single/Dual layer) DVD+R/+RW 8x/8x max. DVD+R DL 6x max. CD-R/RW/ROM 24x/24x/24x max. CD-DA (DAE) 24x max. Sustained Transfer Rate DVD-ROM 11.08 Mbytes/s (8x) max. CD-ROM 3,600 kB/s (24x) max.
Jan 28, 2009 | Computers & Internet
problem writing to Philips DVD-R disc
Ha dell inspiron is a waste dvd.. writer.
i myself have one.
it cant write at a speed more than 4x and nowadays dvds come with 16x speed..
so its always gives error when u try 2 write at low or high speed..
this whole burning process sucks..
im trying 2 find a soln..
as soon as i find one i will tell u
in the mean time
try reducing ur speed to 4x and try
Apr 16, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
Couldn't format and burn the DVD+RW
It could be a problem of the version you are using with Nero 7, try upgrading. It also could be that you are try to burn the DVD RW at a speed it cannot be burned (say 4x), try burning it at 2x.
Hope this works!
Feb 18, 2008 | KHypermedia (KDVRW8X) (20730176) DVD+RW...
cannot write cds at lower speed like 8x
  1. Try to Use Nero or Easy CD creator software for better output.....
  2. Try burning Verbatim 16x DVD+R at 16x first and then burn another of the same type at 8x. And then compare the results. Most times, burning 16x-rated DVD+R/-R media at 12x or 8x will result in fewer PIEs/PIFs.
Whether 1x is better than 8x is another issue. Personally, I prefer 8x speed for most media I use these days (rated at between 4x to 16x but mostly 8x.)
Nov 26, 2007 | Computers & Internet
432 people viewed this tip
David Payne
David Payne
