Tip & How-To about Computers & Internet
Storing of password while using internet.
Kindly do not check the box in case you have to keep on changing your password as it is not necessary that the computer will pick up the last password you have updated which will not allow you to access the said site.
Computers & Internet Logo
i have forgotten my password how can i bypass it or get into it wirhout password
Have you try to bypass computer password in safe mode?
The steps as following:
First, you should restart your computer, and keep pressing F8/F2 to enter the Safe mode.
Second, after enter the safe mode, you can see the default administrator account, just click it to enter the system.
Third, open User Account in control panel, pick the account you have forgotten the password to change the password.
At last, restart the computer, you will log on with the newly created password or without password
If the above method can not help you bypass computer password, you can google search for Smartkey Windows Password Recovery to help you
May 02, 2012 | Samsung R Computers & Internet
I bought a asprie 5100 from a pawnee shop. Little did i know the last owner left the password on there and now i cant get into it. how do i get into it to get the password off it?
If the default Operating System, i.e. windows xp is still installed, you can try login using the Administrators account. Once you reach the Login screen, press Ctrl+Alt+Del two times, you'll get the classic login box with username and password box. Usually the admin password is left blank, in the username box, type in "Administrator" (without quotes) and leave the password box blank and press Enter or click "Ok". If you are fortunate, you'll be able to login with the Administrator's account. You can make the changes with the default user account which is password protected once you are logged in as Administrator. If this isn't working and there's a password with the administrator's account or if it's not windows xp, your only option is to format it and reinstall the Windows.
There are several methods, but those are not authorized to apply without proper license and without authorization and will termed as Illegal if found. Actually it's System administrator's or System engineer's job to do all these.
In fact, this technique is not allowed to us
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 02, 2010 | Acer Aspire 5100 Notebook
how do i change my password?
How do I change my password? Last Updated: February 26, 2010 Text Size: A A A Save to My Help Save this article to My Help for easy reference. You can visit the article at any time from any computer.
Save Cancel Replace an article You have reached the maximum number of saved articles. Your oldest saved article will be replaced with the new one.
Replace Cancel You fill out a form asking you to enter your old and new password.
To make it easier to remember passwords, it is common for people to use the same or similar passwords on each system, such as their birthday or the name of their pet or relative. Simple passwords make it easier for others to guess them. Some people use automated programs that run through common words to guess passwords. To better protect your account, make sure that your password is easy for you to remember but impossible for others to guess.
Never use a password you have used in the past, and do not share your password with anyone. Your new password must be a minimum of six characters and a maximum of 31 characters. We recommend that you use a combination of uppercase and lowercase letters and numbers. The password box is case-sensitive, that is, it can tell the difference between CASE and case, for example, and we recommend that you create your new password to take advantage of that case sensitivity.
To make it more difficult for someone to guess your password or prevent them from guessing it, we recommend that you create strong passwords. Doing so helps keep your accounts secure and safe from prying eyes.
For additional information about secure passwords, visit the Yahoo! Security Center.
Here’s how to change your password:
  1. Click the Change Password button below these instructions. You’ll be asked to sign in if you’re not already.
  2. Type your current password in the first box.
  3. Type your new password in the second box.
  4. Type your new password again in the third box to confirm it.
  5. Click Save. You’ll see a message telling you that you have successfully chosen a new password. If your new password entries didn’t match, go to step 2 and try again.
  6. Click Continue. The Account Sign-in Settings page appears.
  7. Type your new password, and click Sign In. A page opens with your account information. You have successfully used your new password.
Please write your password down, and keep it in a safe place for later reference. Many people forget new passwords when they change them.
Now you can navigate to your Yahoo! services, such as Yahoo! Mail and Yahoo! Messenger, using the links and icons at the top of the page.
Your Yahoo! password always applies to your entire Yahoo! account. This means that it is valid not only for Yahoo! Maill but also for Yahoo!'s other personalized services, including the following:
  • Yahoo! Messenger
  • Yahoo! Chat
  • My Yahoo!
  • Yahoo! Finance
Mar 28, 2010 | Yahoo Mail
I need to change network key in my wireless router...how?
Hi Friend,
In order to change the network key kindly follow the steps:
Please connect the router to the computer first.
1.Start> Run.type cmd and hit enter.
2.In the black box type ipconfig/all and hit enter.
3.Kindly note down the default gateway.
4.Now open internet explorer and in the address bar
type the default gateway number and hit enter.
5.If you have not changed the default password of the router then kindly do not type anything in the username box and in the password box type admin and hit enter.
6.In the setup page click Wireless.
7.Under wireless tab click wireless security.
8.Select the security mode or if it is already selected then you can change the password.
Kindly set the password something that you can always remember.
Enjoy
Regards
Chiranjeet
Mar 18, 2010 | Linksys Wireless-G WRT54G Router
151 people viewed this tip
David Payne
David Payne
