Tip & How-To about Computers & Internet
Restarting of Your laptop.
In case your laptop hangs please do not restart your desktop immediately as this can lead to having bad sectors on your hard disk and all the data stored there could get corrupted or lead to a hard disk crash or can also blowup your power supply. Further if the system is doing a scan of your hard disk do not skip this operation as in some cases it can repair minor problems caused.
Computers & Internet Logo
View Link. But under answers, someone mentioned "Bad Sector", after reading the description, any fixits I can do?
BAD SECTORS
When a hard drive has bad read/write sectors it means the magnetic oxide layer on the disc platters are failing. Before you made an image of the hard drive you should have ran Error Check on the C Drive. This checks and locates the bad sectors and moves the data to an undamaged part of the disc platters and then locks out that bad sector so data cannot be written on the bad sector.
I recommend you do a fresh Windows install on your new hard drive to fix this problem and install the laptop's device drivers plus your programs and data before the hard disk fails completely.
Mar 25, 2013 | Computers & Internet
The hard drive get hanged when data is transferred to it and a noise is heard from hard disk
It sounds like you might have some bad sectors on the drive. If you do it might be time for a new one. Read this article for more info on how to check your drive.
http://support.microsoft.com/kb/315265
Jul 09, 2008 | Hitachi (HTS424040M9AT00) 40 GB Hard Drive
BAD SECTORS
Your hard drive is divided into bits called sectors. When these sectors start to go bad, that means that the computer cannot read or write any data on those sectors. You cannot remove bad sectors and once you start seeing bad sectors it is a sign that your hard drive is about to crash permanently so you need to replace your hard drive and make sure you back up all ofyour important data immediately.
Jul 06, 2008 | Computers & Internet
I have bad sectors in my Hard Disk
try scandisk from your pc. bad secotors are a sigh that your hard drive is going out. I would not use a hard drive that reads bad secotors. scan it first with AVG
http://avg.download-go.com/ its free.
Mar 17, 2008 | Computers & Internet
235 people viewed this tip
David Payne
David Payne
