Tip & How-To about Microsoft Wireless Laser Mouse 5000
Wireless Optical Mouse Cleaning
Optical Mouse Cleaning is a problem for many. The mouse cursor seems to randomly jumping around and uncontrolable, which is caused by dirt on the optical beam. To prevent this from happening, place a piece of clear scotch tap over the optical lens and it will prevent dirt from getting into the lens. Then you won't have problems caused by dirt.
Microsoft Wireless Laser Mouse 5000 Logo
the cursor does not go where you point it. that makes the page jump around
Try another pad. If it's an optical mouse - check there's no dust/dirt covering the lens.Try another pad. If it's an optical mouse - check there's no dust/dirt covering the lens.
thank you
Mar 10, 2010 | Computers & Internet
cursor jumps all over with a touch of the mouse why
trackballs and other ball mouses have an optical sensor inside the cup that holds the ball. dirt, lint and debris that falls into the optical sensor can make the cursor jump around - the sensor detects the debris as if it were a ball movement. Clean the inside of the cup and the jumping should stop.
Cleaning the cup -- first clean the three points that hold the ball up. They tend to grap whatever dirt or grease gets onto the ball from the user's hand. Clean the rectangular sensor window with a que-tip or by blowing into it. Get any stuck debris out of the corners. Finally, turn the mouse over, without the bal inside, and tap it on a hard surface. This can knock loose any remaining debris that can fall into the sensor window.
Dec 11, 2009 | Logitech Trackman Marble FX Trackball
The cursor moves randomly while I use the trackball
this problem is caused by a defective mouse, replace it.
Sep 09, 2009 | Logitech Marble Mouse Trackball
Mouse Cursor Jumps to the right of the screen
Have you tried going into the control panel - mouse - pointer options - motion speed (slower) and experiment with pointer precision check box? Try it, see what that gets ya.
May 05, 2009 | Dynex Wireless Optical Laptop Mouse...
2,181 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
