Tip & How-To about Digidesign 003 Rack Firewire Audio Interface Promo/Demo License for PC, Mac, Sun (9900-38730-00)
When Using ADAT with Digidesign Interface (Fix pops & clicks)
When you connect a device (a lightpipe optical ADAT for example) to your audio interface such as the Digi 003 be sure to change the "Hardware" settings in the File Menu, from internal to optical, and ADAT for using for using an optical ADAT device, such as the M-Audio Octane. This will stop the pops and clicks that happen when the clocking is not set for ADAT.
Digidesign 003 Rack Firewire Audio Interface Promo/Demo License for PC, Mac, Sun (9900-38730-00) Logo
can I connect an audio interface (mine is a Focusrite saffire 56) via ADAT cable. Will I receive 5.1 signal from my interface?
Hello, If by ADAT you mean optical cable then the answer is yes. Digital optical cables support up to Dolby 5.1 surround. Thanks, FJD
May 11, 2016 | Onkyo TX-NR609
how so i expand the outputs on a motu using adat
You have to goto motu audio/midi setup an config the optical output to adat and make sure you set the sample rate to 48000 and check your setting in audio/midi setup in your system preference under mac this should solve the problem.
Dec 08, 2008 | Motu Traveler (8250) Audio Input
what is the SNR
The STAC9221 is deigned for media-centric systems such as Media Center PCs, Game Enthusiast PCs, and new classes of devices aimed to distribute music and video around the home. The STAC9221 sets the standard for high performance by providing 8-channels of true 24-bit audio with a 105dB SNRSee signal-to-noise ratio.
..... Click the link for more information.
(Signal-to-Noise Ratio). This level of performance enables theater quality 7.1 surround sound to PCs and PC-like devices that continue to move into the living room alongside or in place of traditional consumer electronics gear. The STAC9221 incorporates an ADAT(R) Lightpipe interface allowing connectivity to professional audio equipment. The STAC9220 provides 95dB SNR performance setting the standard for the high volume, mainstream desktop PC and high end notebook PCs
Hope that helps.
For more see;
http://www.thefreelibrary.com/SigmaTel+Announces+the+STAC9220+and+STAC9221+8-Channel+High...-a0126662778
Jan 15, 2008 | Computers & Internet
500 people viewed this tip
Top Digidesign Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
