Tip & How-To about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Xp goes black after splash screen
  • Go to regedit: HKey_users .Default Software Microsoft Windows CurrentVersion Internet Settings Digest
  • Delete the Hosts sub key and Reboot.
  • Upon Reboot go back into the key and go to security permissions for just that hosts key (it will be recreated).
  • Select the “System” and click on Deny in Full Control and read access (this prevents the system from writing hundreds/thousands of erroneous entries
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
cant change my wallpaper iv checked all the settings and its not there
HEY HI
you can try this if you are using a windows 7 operating system.
Right-click on Desktop and make sure "Lock Web Items on Desktop" option is not enabled in "Arrange Icons by" menu. If its enabled, then disable it and your problem should be solved.
if the above doesnt here's another quick fix for this
open registry:-start>>run>>regedit(you can type in the start bar even)
1. Open regedit and goto following keys one by one:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\ Policies
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\ Policies
HKEY_USERS\.Default\Software\Microsoft\Windows\CurrentVersion\ Policies
2. Under these keys, if you see "ActiveDesktop" key, delete it.
3. Now Look for "System" key under "Policies" key. If you find it, then select it and look for a string value "Wallpaper" in right-side pane. If it exists, then delete it.
4. Restart your system and you should be able to set the wallpaper.
i beleive this should work.................have a great day
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Feb 27, 2011 | Computers & Internet
1)dell, optiplex GX520 2) SINCE ONE MONTH I TRIED THROUGH ANTI VIRUS I,E WINDOW DEFFENDER BUT NOT REMOVE
Manual Method:
Kill Process
1. Press CTRL+SHIFT+ESC
2. Windows Task Manager should pop up
3. Go to "Processes" tab
4. Kill "WP345d.exe", "eb.exe", "fix.exe", "ppal.exe" by ending the process. (There may only be one of these listed)
5. A warning prompt will come up, Click Yes to End anyway.
6. To confirm the spyware is no longer running, the icon should dissapear when you hover your mouse over the system tray in the lower right. (The icon is a red brick wall)
Remove Registry Keys
1. Press WIN+R (The WIN key is the key between CTRL and ALT that looks like a Windows logo)
2. In the run box, type "regedit"
3. Windows Registry Editor will pop-up. *Be cautious when editing the registry*
4. Navigate to the following folder on the left-hand pane, and delete the listed items below:
HKEY_CLASSES_ROOT\CLSID\{3F2BBC05-40DF-11D2-9455-00104BC936FF}
HKEY_CLASSES_ROOT\WP345d.DocHostUIHandler
HKEY_USERS\.DEFAULT\Software\Microsoft\Internet Explorer\SearchScopes "URL" => "http://search-gala.com/?&uid=201&q={searchTerms}"
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer "PRS" = "http://127.0.0.1:27777/?inj=%ORIGINAL%"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings "UID" = "201"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\User Agent\Post Platform "89770891803"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Windows PC Defender"
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run "Windows PC Defender"
Registry Locations may vary, If you can not locate a certain item, use Edit > Find and type in the name of the key in quotes, For example:
To find...
Search for "Windows PC Defender" without quotes.
4. Delete the Folders
Navigate to the following folders through My Computer, and delete the listed items.
C:\Documents and Settings\All Users\Application Data\
Delete the folder "3ad5ffe"
c:\Documents and Settings\All Users\Application Data\
Delete the folder "345d567" (This is a randomly generated set of numbers/letters)
Delete folder "WPCDSys"
%UserProfile%\Application Data\ (Copy-Paste into Explorer's Address bar)
Delete folder "Windows PC Defender"
5. Reboot the PC and then refer to Step 1 to finish clean-up with MalwareBytes if necessary.
Oct 27, 2010 | Symantec Norton Internet Security 2009
how can i fix m3plugin .dll error
Do the following step and get rid of it.
Open Run , type regedit and press enter
Go to
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
and check for the key Shell, the value of this must be Explorer.exe . if you can see some other after that like Explorer.exe C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then remove the second file from the value, means it must only Explorer.exe
In Regedit go to;
and delete any value except "Default".
then go to;
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
and delete value except default and anti virus.
Best of luck.
Hasan
Dec 05, 2009 | Intel Motherboard
In my pc my task manager is no working longer, so how can i fix it, and uses it again.
Verify that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
Task Manager in the Local Group Policy
1. Go to "Start" -> "Run" -> Type "Gpedit.msc" and press on "Enter" button.
2. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
3. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".
4. Close "Gpedit.msc" MMC.
5. Go to "Start" -> "Run" -> Type "gpupdate /force" and press on "Enter" button.
For the "Domain Group Policy" Verify correct registry settings::
1. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
2. Navigate to the following registry keys and verity that following settings set to default:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system\]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"DisableCAD"=dword:00000000
3. Reboot the computer.
Jun 06, 2009 | Microsoft Computers & Internet
2,765 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
